New camaro
Car: 25th anniversary RS
Engine: 3.1L v6
Transmission: Automatic
New camaro
Hey I'm sorry if this isn't the place to post, really new here. I bought a new camaro today and before this I've always had trucks. I bought it and it started fine but now every couple times it will just click and not roll over, after a couple tries it will though, any ideas of what it could be? And also the gas pedal is really stiff and almost impossible to ease into is that normal or can I adjust that?
Car: '87 Iroc
Engine: 350 TPI with Holley Terminator X
Transmission: 4L60e
Axle/Gears: Stock/ Factory
Re: New camaro
Sounds like the starter, you can take and have it checked. Before you pull the starter check the battery though.
Car: 85z28(sold),91 rs, 15'Mazda3GT
Engine: 5.7L V8 350 (ZZ4)
Transmission: 700r4 rebuilt with kits+ vette serv
Re: New camaro
There's a lot of possibilities on why it won't start, you can start off by checking the battery then starter. Or if the Ignition switch was just replaced, might wanna check it if it pushed all the way back (I just fix that on mine after replacing everything lol). Again a lot of possibilities
84z96L31vortec
Aug 20, 2017 12:16 AM
