3.1l no start (still!)
Old Jul 15, 2014 | 09:53 PM
  #51
Stewie's Avatar
Car: 1992 Firebird
Engine: 3.1L
Transmission: Manual T5
Axle/Gears: Stock
Re: 3.1l no start (still!)
Looks like you've narrowed down the problem. With these cars, sometimes, it feels like chasing ghosts before you find the gremlin causing all the misery.
Old Jul 16, 2014 | 05:36 PM
  #52
draco's Avatar
Car: 1992 Camaro RS 25th Anni.
Engine: 5.0l TBI
Transmission: 700R4 Automatic
Axle/Gears: 3.73 Gov lock
My father made another observation this morning. Car would not start, moved the steering column and it started. Not sure if it was coincidence or if there is a problem in the column. I have my VATS bypassed with resistors under the dash, so i dont think the anti theft is the culprit. Is there anything else in the column that could cause a crank but no start condition?
Old Jul 17, 2014 | 06:38 PM
  #53
draco's Avatar
Engine: 5.0l TBI
OK did some back probing. Here's what I've pinned down so far as definite.
TPS - Ground is good
Signal is 0.70 (at close) - 4.50v (at WOT)
Reference 5.02v
MAP - Ground is good
Signal is 4.81v at 0 vacuum, decreases as I suck on it with my mouth.
reference 5.13v
Old Jul 17, 2014 | 08:49 PM
  #54
draco's Avatar
Engine: 5.0l TBI
more to add:
Removed IAC and remeasured, and it is at the correct length.
Checked for IAC signal at KOEO, and it is present.
Removing O2 sensor from exhaust did not change anything.
Further notes :
After extended starting attempts, the purge solenoid on the charcoal canister feels very hot, I don't think it's related or causing a massive vacuum leak because capping off the hose to the motor gave no change in condition.
Removed the vacuum tubes from the top of the throttle body and noticed there is no vacuum pull there, but there is vacuum pull on the rear of the intake? (The FPR pulls vacuum from the back of the throttle body)
Noticed that the oil pressure sending unit has been leaking oil for some time, ran the wiring diagram for that circuit, which runs through the fuel pump circuit, however my fuel pump is running properly and is testing at 44psi. Although my oil pressure gauge often reads near zero at idle sometimes, so that's a future fix.
Im about 2 weeks away from taking the camaro to a garage that has the older OBDI diagnostic scanner, maybe the data stream can shed some light. Either that or parting it out into my 87 project and get the v8 swap boogie started.
It's awful that I'm an ASE certified technician in Engine repair, Brakes, Steering and Suspension, Electrical Systems, and I'm hitting a brick wall here.
Old Aug 5, 2014 | 10:56 AM
  #55
strrtwinkle's Avatar
I wanted to let ya'll know that the car is running but had to take it to a mechanic so won't try any more, I want to replace this piece then make up my mine if I need to sell it, now on a fixed income so money is tight and if it breaks down again then it will sit again. Can anyone tell me where to go to find this part.....I can't figure out how to put a picture here.. so the part is in front of passenger wheel and where nose fits on side about a foot below turn signal on side. I have no idea where to start looking, I've looked in junk yards for light motors and you just don't find these cars in there. Hope someone can help.
Old Aug 5, 2014 | 05:54 PM
  #56
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Good luck with that mechanic. A lot of them have probably almost never even seen an OBDI vehicle much less worked on it. You'll probably spend a grand before he gives up and you're still stuck in the same boat.
The part you're looking for is either an air deflector (air dam/headlight protection piece) or the ground effect (commonly broken part).
Old Aug 5, 2014 | 07:15 PM
  #57
Thanks for getting back , I know it has nothing to do with the headlight , I do believe it's ground effects but don't know what that certain part would be called, I looked at one of the vendors here but what I saw didn't look like what I needed. Well I paid over 1/2 that which is why I won't be able to put much more into it, needs tires as these have been sitting long enough to start to dry rot.
Old Sep 5, 2014 | 03:03 PM
  #58
russb217's Avatar
have 92 camaro with 3.1 at first it would fire right up then shut down,now will not start at all
Old Sep 5, 2014 | 03:25 PM
  #59
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Welcome to TGO. You should start your own thread so it's fresh. Explain all the symptoms and engine details with regard to what's old/new and any changes that may affect it.
Old Sep 28, 2014 | 01:24 PM
  #60
91CamaroRSv6's Avatar
I bought this 91 3.1 mpfi off a high school buddy for 450 bucks, needed a starter and plugs before i drove it 20miles home. had sat for a year and had shitty gas, put lucas and a full tank in it. drove it for bout 5k miles and it broke down NUMEROUS times, keep fixing it and it just keeps breakin down. NEED HELP DESPERATELY
Old Jun 16, 2015 | 10:19 AM
  #61
GTracin07's Avatar
im having the same issues and tried alot of whats mentioned here, what ended up fixing your issues?
Old Jun 16, 2015 | 06:54 PM
  #62
GTracin07's Avatar
this is what my car does i feel like ive checked everything
Old Jul 10, 2015 | 09:06 PM
  #63
draco's Avatar
Engine: 5.0l TBI
**Update**
After getting the car running with several replacement parts listed above, determined oil pressure sender had burnt area in harness, about 1 inch long from the connector up on the orange wire. Determined oil sender shorted. Replaced it along with fuel pump, strainer, and in tank harness.
and now she runs, and starts everytime.
But something is still wrong, misses at idle, clears up off idle but occasionally "hiccups", my catalytic converter is cherry red on the tail end before the car reaches operating temp, and my tach is showing idle at 2000-2500 RPM. I can tell by ear its running much slower than that. Bumping the throttle shows 5000rpm at what sounds like 2000 rpm.
I have the EGR valve plated off at the exhaust manifold and intake. Could this be related?
jhawkeye
May 25, 2022 06:33 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
92camaroJoe
Aug 13, 2015 06:07 AM
92projectcamaro
Aug 6, 2015 01:20 PM
