which flywheel needed?? for v6 manual
Old Aug 31, 2013 | 11:02 PM
mooch1's Avatar
Car: 1985 camaro Z/28
Engine: 305 V/8 4bbl carb
Transmission: T5 WC
Axle/Gears: 3-23 posi with 4 wheel discs
hi, i just picked up a 1984 firebird 2.8 v6 automatic,,,the owner also gave me a manual T5 and most of the parts for a swap to manual,,why not?
the only issue is that the car i a 1984 but the v6 has been replaced,,it is carb engine...which and where would i get a manual flywheel to do my swap? thanks.
Old Sep 1, 2013 | 11:46 PM
caffeine's Avatar
Car: 89 Firebird Formula
Engine: 3500T
Axle/Gears: 9 bolt/4.11
Re: which flywheel needed?? for v6 manual
You need to either find out what year the engine is from or remove the flex plate to find out if it has a weight on it or not. There are two types of flywheels; '82-'87 and '88-'95. 82-87 have a weight on them and are not neutrally balanced. 88-95 are neutrally balanced.
Just because it has a carb on it doesn't mean it's a pre-88 engine necessarily.
Old Sep 5, 2013 | 05:53 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
You should be able to find the casting number on the block, I believe on the back of the driver's side, right by the bellhousing. Hopefully its not too dirty to read.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Pac J
May 17, 2020 10:44 AM
Fireslash
Apr 11, 2016 06:43 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bjpotter
Oct 4, 2015 07:48 PM
