calling daves12v6 or any of the turbo v6 guys on here
Old Oct 1, 2013 | 07:23 AM
92camarorv6's Avatar
Car: 92 camaro rs
Engine: 3.4v6 sc
Axle/Gears: 9 bolt 3.73s
ok so i want to put a bigger cam in my camaro it has a small one now but i want to go bigger daves12v6 links are all down for the cams in his sticky
and was it something like dona cam's there like 160 bucks? and if this site is died for the turbo guys were did you all go so i can join you all
Old Oct 1, 2013 | 08:54 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: calling daves12v6 or any of the turbo v6 guys on here
IIRC, it was Delta Cams (http://deltacam.com/).
RBob.
Old Oct 1, 2013 | 02:56 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
delta cam 260 or 272 grind. A 272 would be the better choice for a turbo build. Be sure to get a properly matched stall converter and better valve springs.
Old Oct 3, 2013 | 07:57 PM
Car: 92 camaro rs
Engine: 3.4v6 sc
ok thanks guys
Old Oct 18, 2013 | 06:38 PM
Car: 92 camaro rs
Engine: 3.4v6 sc
what would be a a good stall eddi...
on a side note what happen to dave and frocedfirebird and that other guy cant reacll his user name
86White_T/A305
Mar 6, 2016 01:48 PM
cheesehomer
Dec 31, 2015 08:48 AM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
New2Chevy
Sep 28, 2015 12:35 AM
R13_Braz
Sep 18, 2015 05:00 PM
