MAF sensor
Old Oct 9, 2013 | 11:13 PM
MitcherNeaf's Avatar
MAF sensor
So guys I am trying to find the wire that plugs into the maf sensor. Any help here? I have a 92 with a 3.1 with a front end from a pre 89. Where am I supposed to be looking?
Old Oct 10, 2013 | 12:58 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Re: MAF sensor
It's a MAP sensor on the '92 and it should be mounted on the firewall on the passenger side. Follow the vac line from the back of the plenum.
Old Oct 10, 2013 | 06:30 AM
Re: MAF sensor
Oh ok so the maf sensor must be from the front end. Thanks that helps!
Old Oct 18, 2013 | 07:03 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: MAF sensor
There isn't a MAF on a 90-92, period. If you're getting either a code 33 or 34, the system is referring to the MAP. If your car has a MAF (and chances are it doesn't unless someone did some serious screwing with the engine controls), it will be in the air duct between the filter and the throttle body bellows.
BumpaD82
Feb 26, 2016 02:57 PM
sleprock
Oct 1, 2015 09:39 AM
Racerx974
Sep 19, 2015 10:16 AM
Ikes 91Z
LSX and LTX Parts
Sep 13, 2015 09:03 AM
earlpote
Sep 12, 2015 11:55 AM
