Heater valve and tb delete?
Old Oct 30, 2013 | 10:52 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
I can't find a definitive answer for deleting the heater valve and bypassing the throttle body. The small pipe from the water pump sends water to the heater and throttle body and back to a pipe at the thermostat housing. Can I plug both of those and not have a flow from the pump to the thermostat housing? Or must there be a flow for some reason?
Old Oct 31, 2013 | 01:19 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: Heater valve and tb delete?
use a section of hose to bypass it, still flowing but not into TB.
never had one, gets plenty cold here in NW Ohio, its not needed.
Old Oct 31, 2013 | 01:32 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Not just bypassing TB. I've got no heater so can I plug the output from the pump and the inlet on the thermostat housing? Or must coolant still flow from the pump to the thermostat for some reason?
Old Oct 31, 2013 | 02:46 PM
project89's Avatar
if u look at the whole system , it allows coolant to bypass the thermostat when its closed , it does this slowly so the coolant near the thermostat is the same temp as the coolant in the rest of the system pre radiator.also there is less drag on the waterpump this way
oif u want to completly eliminate the system take the thermostat out and drill 2-4 1/8th inch holes in the sides of the thermostat , and then plug off the reat of the system , drilling the holes alows for some coolant flow around the stst without the rest of the system in place
2 holes should be enough , i have 4 on my 355 turbo motor , with no heat or other bypass system and it works just fine , though we just got our first snow so ill be putting the heater back in , the camaro is still cheaper to drive day to day when the roads are good compared to the chevy 2500 4wd silverado
Old Oct 31, 2013 | 03:48 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Got it. I'd probably go with a pipe direct form the pump to the thermostat so re-instating for smog (CA) will be easier. Thanks.
Old Oct 31, 2013 | 08:02 PM
project89's Avatar
none of the heating system has anything to do with smog check, so u should just be fine getting plugs or caps
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
Nick McCardle
Sep 10, 2015 08:36 PM
mantaguy
Sep 2, 2015 10:42 PM
