Poor mpg
Old Mar 11, 2014 | 01:44 AM
turbota82's Avatar
Car: 1989 Formula
Engine: l98
Poor mpg
I have a 3.1 in my bird. I had to replace the fule pump a few months back so I replaced the filter and strainer as well. Anyway getting poor mpg like 200 miles per tank also seem to have presure in the tank as well as a humming noise when I've got about a 1/4 tank of gas left. Any ideas or suggestions guys thanks.
Old Mar 11, 2014 | 06:29 AM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Re: Poor mpg
Could be lot of things. Doing a good ole tune up might help. Plugs, wires, cap and rotor, make sure the sensors all work, stuff like that. Does the exhaust smell rich all the time?
I wouldnt think the fuel pump or filtration has any issues. Although your charcoal canister may have some problems if its building pressure. But from my own experience, having the canister removed and other emission, it wont hurt the mpgs as bad as what you are saying. Your getting like 14mpgs or so. Is this mainly city driving or highway averages also?
Old Mar 11, 2014 | 10:51 PM
turbota82's Avatar
Car: 1989 Formula
Engine: l98
Re: Poor mpg
Thanks! Mpg is a combo of hwy/city I replaced the plugs an o2 but I am getting a code 13. I do smell gas most of the time. Thanks for the info.
Old Mar 12, 2014 | 02:34 PM
Mark RWC's Avatar
Re: Poor mpg
Code 13 is a faulty oxygen sensor. Did you have this code with the orignal part? If you did not and the conector is good and all the way on put the old back in reset the ECM and check your codes.
If you smell the gas under the hood pull the vacuum line of the fuel pressure regulator and see if has gas or a strong gas smell. If it does have gas in the vacuum hose replace the regulator.
I would test the fuel pressure on the fuel rail and also make sure it holds close to normal pressure for atleast 15 minutes. Leaking fuel injectors are another possible problem. The fuel pressure test will help you to find the problem.Fuel pressure should around 38-46 psi.
Old Mar 12, 2014 | 10:38 PM
turbota82's Avatar
Car: 1989 Formula
Engine: l98
Re: Poor mpg
Thanks guys I'll check ASAP and get back to you.
Old Mar 13, 2014 | 08:22 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Poor mpg
If the stock Multec injectors are still in the engine, replace them.
Code 13 is due to an inactive O2 sensor.
RBob.
Old Mar 15, 2014 | 12:26 PM
willexoIX's Avatar
Car: 89 Camaro RS running MS2X
Engine: .48/.60AR T3/T4 2.8L V6
Transmission: Rebuilt 700R4 2500 stall
Axle/Gears: Next to break...
Re: Poor mpg
RBob.
Make sure the connection for the O2 is good at the sensor and check the injectors and go from there.
Old Mar 15, 2014 | 09:14 PM
ex-x-fire's Avatar
Re: Poor mpg
Make sure the engine is getting up in temp, should be 190-200* while going down the road. The coolant temp impacts fuel economy.
92firebirdguy
Sep 1, 2016 07:53 AM
Mdenz3
LSX and LTX Parts
Dec 10, 2015 11:18 AM
Saxondale
Carburetors
33
Oct 1, 2015 10:26 AM
James Sutton
Sep 23, 2015 02:18 PM
ssgt usaf
Sep 21, 2015 12:45 PM
