cant find elusive misfire
Old Apr 22, 2014 | 08:18 PM
chikenbag's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.1L V6
Hey guys, for the longest time I have been trying to find the cause of a mysterious misfire and its driving me nuts. other than the misfire the car runs great, and the misfire seems to happen more frequently when the car is warm. it only does it while the car is idling in park or drive.
its a 1992 camaro 3.1L v6 auto and these are all the parts that have been replaced:
fuel pump
injectors
spark plugs
spark plug wires
distributor
distributor pickup coil
ignition control module
cap and rotor
coil pack
idle air control valve
I have also checked for vacuum leaks with a can of carb cleaner and couldnt find any. I look forward to and appreciate any ideas
Old Jun 19, 2014 | 05:07 AM
rs90's Avatar
Car: rs 90
Engine: 3,1
Transmission: 700
Re: cant find elusive misfire
i was really hoping someone could help you with this problem , cause my is acting just like yours ....
or if you solved the problem i like to hear about it
Old Jun 19, 2014 | 07:32 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Is this misfire a light skip from time to time? If so it is normal, an error in the ECM firmware.
RBob.
Breazlan
Sep 25, 2015 11:20 AM
Jk_Under
Sep 8, 2015 08:13 AM
90formulaVortec
Exterior Parts Wanted
Sep 7, 2015 07:17 PM
rjcme
Sep 5, 2015 01:23 PM
