Plastigauge or Not
Old Jun 20, 2014 | 09:51 PM
LarryD's Avatar
Car: 92 RS
Engine: 3.1 V6
Plastigauge or Not
I am starting the reassembly of the 3.4L block for my 92 3.1 to 3.4 swap. The machine shop got a 0.010 turned crank and new bearings for the 3.4 when they put in the new cam bearings and honed the cylinders. What's your thought on the necessity of running through the whole plasti-gauge routine for the bearings on the mains and rods?
Thanks...
Old Jun 20, 2014 | 10:59 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: Plastigauge or Not
good idea, seen to many sloppy shops that think, good enough for what your doing, if their not impressed with your engine or build of choice.
Old Jun 21, 2014 | 05:28 AM
Restrorob's Avatar
Car: 88 GTA
Engine: Built 355 to install
Transmission: Built turbo 350
I trust no machine shop, I plasti-gauge ALL bearings and check ALL ring gaps before assembly. Then clean everything back up and assemble, It's done to find any issues before the engine is in the car and have piece of mind know'n it's right...... I don't like do'n things twice.....
Old Jun 21, 2014 | 12:36 PM
LarryD's Avatar
Car: 92 RS
Engine: 3.1 V6
So, anybody know what size plastigage and the acceptable measurements for the main and rod bearings for the 95 3.4L block?
Also, are the torque specs for the 3.4L main and rod bolts on here somewhere?
Thanks...
Old Jun 21, 2014 | 03:28 PM
Restrorob's Avatar
Car: 88 GTA
Use .001 to .003 plasti-gauge, A good number is .002 on most all engines. While your at the auto parts store buying plasti-gauge (one strip will do) buy a Chilton's manual for your car, It should have all the specs and torque patterns needed for re-assembly.....
billybob6110
Feb 14, 2014 08:36 AM
rhyspat
Feb 3, 2013 02:24 AM
CamarosRUS
Dec 19, 2006 12:15 AM
spills
Oct 24, 2006 11:32 AM
StealthElephant
Aug 16, 2004 04:47 PM
