Possible Oil Pump problem
Old Sep 14, 2014 | 06:05 PM
Domsfirebird's Avatar
Car: 1986 Pontiac Firebird
Engine: 2.8L V6 MFI
1986 Pontiac Firebird 2.8L V6
So here is the deal, not sure what it is but I'm leaning towards a bad oil pump. I haven't tested anything yet because of lack of money! This is the problem I am having: When my car is started I hear a noise similar to a playing card in the bicycle spokes. When I accelerate it gets even louder. When I come to a complete stop or put the car in park after driving it, the oil light comes on and off. This all started to happen when I found out my headlight switch went bad, and was killing my battery. When jumping my car this noise started to happen. So like I said I believe its a bad oil pump but I have no idea. Thanks for any suggestions guys!
Old Sep 19, 2014 | 08:16 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: Possible Oil Pump problem
Have you poked around under the hood to find out what area the noise is coming from? It could be any one of a gazillion things...
Might also take it to have an oil pressure test done...
Old Sep 22, 2014 | 08:12 AM
JC1992rsconvert's Avatar
Car: 1992 camaro rs convertible
Engine: 3.1 liter v6
Transmission: automatic
Axle/Gears: 3.23 posi trac
when my oil pump went bad i went to three different mechanics and they all said it was a bad lifter now to worry about it well engine over heated and slung a rod burnt bearing and no rings on the pistons so now im out of a motor for mine never seen a check engine light or anything until it over heated just putting my two cents in but if it is your oil pump listen very closely to the bottom end and see what they can bring up
Old Jul 25, 2015 | 10:25 PM
bubbazwv's Avatar
Car: 1987 Camaro SC
Engine: 2.8
Domsfirebird what happened???
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
toronto formula
Nov 10, 2015 06:17 AM
Navy8125
Aug 21, 2015 09:32 AM
92camaroJoe
Aug 13, 2015 06:07 AM
