ignition timing
Old Nov 10, 2014 | 09:21 PM
Armada95's Avatar
Car: 1991 Chevrolet Camaro RS
Engine: Chevy 350 HSR TPI
Axle/Gears: 3.23 Open
ignition timing
Hello, I have a 1991 camaro rs with the 3.1 in it, I'm having a hard time getting it to start because the ignition timing is off, i've put the #1 cylinder at tdc in the compression stroke and dropped the distributor in so the rotor Is in line with a point on the cap to set base timing , when I try to start the engine it turns over and tries to start causing backfires and sometimes just turning over, I know it's a ecm controlled distributor but I should still mechanically get it started then set the timing, i've tried turning the distributor clockwise and counterclockwise to try and get it running but no luck. Any help would be grateful, from my research I'm reading the front passenger cylinder as #1 and that's what I have it set to with 1,2,3,4,5,6 firing order, it is a crossfire engine.
Thanks for any help you guys can give
Old Nov 11, 2014 | 05:49 AM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Re: ignition timing
When you set the distributor make sure you have the rotor on the dizzy pointing at 7 o clock, (aimed to cyl 1) and also be sure the knotch on the balancer is visible on the timing tab. Set it to 0 degrees btdc. That should get it to start. If not you can turn the dizzy a bit to advance it to start it You could have the timing 180 degrees out of wack.
Just take the dizzy out and turn the engine over by hand with a socket on the crank till the notch lines up with 0 degrees btdc on the balencer, then toss the dizzy in making sure to get the rotor to point to that 7 o clock area as best as possible.
And yes firing order is 123456
Old Nov 12, 2014 | 12:45 AM
Armada95's Avatar
Re: ignition timing
Iv tried that and no avail, it just backfires through the exhaust and sometimes the intake, or not at all, I noticed theres 2 timing marks on the harmonic balancer, which one needs to be at 0*? or is there a way to tell what each mark means.
Old Nov 12, 2014 | 05:53 AM
fasteddi's Avatar
Car: 1991 Camaro RS
Re: ignition timing
Line it up with the thicker wider notch
Ghettobird52
Jul 5, 2024 11:18 PM
89GTAOz
May 16, 2020 09:31 AM
Infested
May 22, 2018 11:56 PM
Bryan F
Aug 18, 2015 02:28 PM
