Need help with 92 camaro rs 3.1 vaccum lines HELP
Old Dec 7, 2014 | 12:49 PM
maroe624's Avatar
Car: 92 Z28 Clone
Engine: Vortec 350
Axle/Gears: 3.23 Torsen
Need help with the vaccum line that comes from the fuelpressureregulator.....one end goes to the trhottle body but were does the other end go? I heard it goes to the air pump but i cant find were to plug it in... Also on the back of the intake vaccum lines. Pictures will help please the diagrams dont tell u exactlywere they go... Help
Old Dec 8, 2014 | 01:46 AM
thatoneguy5x's Avatar
Car: camaro
Engine: 3.1
Transmission: auto
Re: Need help with 92 camaro rs 3.1 vaccum lines HELP
the one of the TB does go to the air pump and is a pain to get to. you will need to bend your wrist in ways it shouldn't and use the very tips of your fingers. ive done it a couple times because the line kept melting.
the ones on the back of the plenum go to the map sensor (has its own nipple off the back) the other T's off a check valve and goes to the vacuum ball and one of the small hard lines coming through the firewall by the heater core and AC box (there are 2 of those lines, the other should go to the heater control valve)
sorry if this causes more confusion than answers im having trouble getting a pic up for you.
Old Dec 8, 2014 | 02:51 PM
maroe624's Avatar
Car: 92 Z28 Clone
Engine: Vortec 350
Found it. Thanks bro.
84z96L31vortec
Aug 20, 2017 12:16 AM
sonu1975
Aug 11, 2015 08:38 AM
the_nikfive
Aug 11, 2015 02:46 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
guy76767
Aug 6, 2015 05:58 PM
