Post 3.4L Swap Idle Speeds
Old Jan 26, 2015 | 10:57 AM
LarryD's Avatar
Car: 92 RS
Engine: 3.1 V6
I am looking at having the ECM tuned after the 3.1 to 3.4 swap. Are there any recommended changes to the idle speed settings? My ECM ran the 3.1L at about 1,500 cold and 1,000 hot. This is a 5 speed manual trans...
Thanks...
Old Jan 26, 2015 | 11:04 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Re: Post 3.4L Swap Idle Speeds
Hot idle should be more like 700 I think.
Old Jan 26, 2015 | 08:57 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Don't touch any of the idle related settings in the bin. There's no need to unless something major has been changed. Your engine has either a vacuum leak or needs the idle relearned or needs the minimum air rate reset. Hot idle should be around 600-700 RPM for a 5-speed as according to GM. Idle speed should be around 1200 RPM cold.
Old Jan 28, 2015 | 01:09 AM
LarryD's Avatar
Car: 92 RS
Engine: 3.1 V6
Interesting. I have had this car since new (with the 3.1L) and it has always had a hot idle of 1,000 and cold idle about 1,500 (at least as far back as I can remember since I have been driving it for 22 years)... I have done untold number of relearns over the years and replaced the IAC at least 3 times and always the same on the idle speeds resulted.. Vacuum is rock solid at 15 (needle doesn't even twitch) although I expected higher with the complete rebuild of the 3.4L engine that I swapped in... I was just thinking that it might be different with the 3.4L (although I see no particular reason for that to be the case)...
specialized
Jun 18, 2022 09:26 AM
InfinityShade
Aug 22, 2015 08:00 PM
ezobens
Aug 19, 2015 10:29 PM
perZ
Aug 15, 2015 01:17 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
