confused.... 1984 2.8L, MAP, MAF both or neither??
Old Apr 2, 2015 | 11:57 AM
The Gaffer's Avatar
Car: 1984 Camaro
Ok, I am slightly confused, I have a 1984 2.8l Camaro, with 2 bbl, keep reading that I don't have a IAC, which is fine but do I have a MAP or MAF or both or neither? Trying to trouble shoot a hard start and stumble/stall at idle and at low speeds (braking/turning). Plan on rebuilding the carbs at some stage and also delete/bypass CAT which I think is the original but just looking for other things to check,
Old Apr 2, 2015 | 01:12 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: confused.... 1984 2.8L, MAP, MAF both or neither??
neither its an 84, you got a carb.
maf, map, IAC all computer devices for fuel injection.
anytime a car stalls using the brakes you have a vacuum leak, the brakes use so much vacuum it will suck the life out of a running engine and kill it.
Old Apr 2, 2015 | 08:42 PM
OrangeBird's Avatar
Car: 1989 Firebird
If you check out the wiring diagram for 1984 2.8L over at austin third gen , you'll see that it is an ECM controlled carb (Electronic mixture control) and as such does have several sensors such as a vacuum sensor (MAP) , O2 sensor , Throttle position sensor , Baro sensor , and so on . I would check for Vacuum leaks and also I'd check for proper functioning of the carb's electronic control components .
I'm sorry I can't seem to post a direct link to the page with the 84 2.8 wiring diagram , but if you search www.austinthirdgen.org you should find it . This diagram will show you all the components of your system . I would also look into getting a good troubleshooting guide for the engine/ECM systems as well ....
Last edited by OrangeBird; Apr 2, 2015 at 08:49 PM. Reason: Yep , the direct link to the diagram just ain't gonna work :(
Old Apr 2, 2015 | 10:14 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
He is in Canada, even the s10-15 got just a carb for allot longer then the US models.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
BumpaD82
Feb 26, 2016 02:57 PM
Saxondale
Carburetors
33
Oct 1, 2015 10:26 AM
Ikes 91Z
LSX and LTX Parts
Sep 13, 2015 09:03 AM
CAMAROBEAV
European Region
Sep 12, 2015 09:34 AM
