Car been setting for ten years. Help
Old Jun 20, 2015 | 07:21 PM
snakeshooter's Avatar
Just got a 85 2.8 firebird, the original engine was swapped for Goodwrench 2.8 long block. The engine has about 6 thousand miles on it. The catch is it was changed in 2004 and has setup for the last eight years. What is it going to take to get it road worthy again. By the way one of reasons it was setup was the Goodwrench engine turned out to be Extremely weak. It turned into a real dog. Any help will be greatly appreciated.
Old Jun 26, 2015 | 09:09 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
Re: Car been setting for ten years. Help
Have you tried to start it yet? If it runs, we can go from there, but we need to know where you stand w/ it first.
Old Jun 26, 2015 | 04:43 PM
That was what I was wondering about. Do you think I should drop the tank and all before I fire it up?
Old Jun 26, 2015 | 06:01 PM
drdave88's Avatar
Engine: 6.0L
I say try to fire it up, or at least syphon the gas out, put some new in with a new filter and see how she does. I wouldn't drop the tank unless the pump is dead.
Old Jun 26, 2015 | 07:05 PM
OK I'll get some gas and a filter tomorrow and see how it goes. Thanks for the help!!!
Old Jun 26, 2015 | 08:14 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
I would not risk cloggin injectors, id rev flush it and empty out at the filter, then put on a new filter, to grab junk in back part of lines, that the filter sock wouldn't let escape anyways. But new filter will grab it. Change it soon after 1-2 tank fulls. MMO is good to run heavy in the gas n lube the lines n fuel system moving parts. Smell good too
id watch the cat or for a sudden loss of power, they can either work great, or from sitting long, soon after crumble n clogg up.
Old Jun 26, 2015 | 09:59 PM
how do you recommend reverse flushing it? Can I just use air and gas? Where should I hook up to????
specialized
Jun 18, 2022 09:26 AM
customblackbird
Aug 15, 2021 10:16 PM
midge54
Dec 27, 2019 04:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
TheExaminer
Aug 26, 2015 04:59 PM
