found my oil leak (yeah another one)
Old Dec 19, 2001 | 10:34 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
ok, i just come to the sick realization that oil is leaking pretty heavily from my oil pressure gauge sending unit right next to the oil filter
1. how much do new sending units go for?
2. what kinda tool do i need to take it off and put a new one on.........the nut is rather big, and a socket will not fit over the unit..........theres not much room for a wrench neither.........
Old Dec 20, 2001 | 12:10 AM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
the price on the sending unit will depend on whether you have gauges or lights.
AZ has a rental tool for oil sending units, a BIG deepwell socket, for like $10-15, use it, return it, get money back.
Old Dec 20, 2001 | 12:57 AM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
I got my sending unit at Kragen....it was under $30. I forget the actual price. I think I used an adjustable wrench. No, there's not a lot of space to move a wrench so you'll have to turn it slowly and patiently.
Actually now that i think about it, I changed a sending unit on a Suburban and I used a socket.......so, Snap-On DOES make a socket for this job but it's not required.
Old Dec 20, 2001 | 07:36 AM
ok guys thanx alot!!!!!!!
hah, Snap-On, gotta love them, i just got a whole set of them for school (at my parents expense )
now anyways, i'm gonna make another attempt to reach it from on top after i drain the oil out..........
if that doesnt work, i will have to wait for my dad to get home cuz he is like 1/2 my size and can fit underneath a camaro when its jacked.............
will i need a gasket for the job?
Old Dec 20, 2001 | 08:23 AM
MDv6man's Avatar
Car: 1983, 1986
Engine: 2.8 2bbl, 2.8 MPFI
Transmission: 200C 3 speed, 700R4
Axle/Gears: 3.08, 3.42
No Gaskets required!!!!!!!!!!!!!!!!!
Old Dec 20, 2001 | 10:01 AM
KED85's Avatar
Teflon tape!!!!!
Actually, there are two nuts on the units.
One large at end, one small at fitting itself.
You "Can" get it from top or bottom.
IT's easiest when ya change the filter!!!!
i.e. MORE ROOM!!!!
Wanna cheat?
Go to oil changing place, have them swap the old one out while doing job. Takes five more minutes!
Unless, you're like me, adding the sending unit for the first time, compared to swapping the electric idiot light unit for the guage unit.
Old Dec 20, 2001 | 09:17 PM
ok guys, i tried to get it from the top today with no luck
thats ok though
my dad is gonna jack the car up saturday morning and do it for me
should i seriously use teflon tape???
anyways, i have bigger problems..............when i drove the car out of the garage after diagnosing this problem, MY POWER BRAKES DO NOT WORK
AND MY IDLE SURGES FROM 1000-4000 RPMS!!!!!!!!!!!!!!!!!!!!
HELP ME!!!!!!!!!!!!!
i am thinking that this is a vacuum problem.............
either that or i bent a brake line...........but i dont think I did, becuz all i did was wiggly one slightly to get a wrench onto the sending unit
but why the surging RPM????
thanx in advance guys
Old Dec 21, 2001 | 09:03 AM
PERSEVERANCE!!!!!!!!!!!!!!!!!!!!
I DID IT!!!!!!!!! and i also noticed where my 4000 rpm idel and loss of power brakes came from!!!!!!!!!!!!!!!!
i accidently knocked loose a vacuum line from my master cylinder~!!!!!!!!!!!!!!
HIP HIP HOORAY!!!!!!!!!!!!!!!!!!!!!]
now my mommy aint gotta drive my sorry *** around!!!!!!!!
and no more burning oil fumes!!!!!!!!!!!!!!!!!!!!!!!
Old Dec 21, 2001 | 08:05 PM
Joe_L's Avatar
Car: 1995 Z28
Transmission: Built 4L60E
Axle/Gears: 3.23's - Limited Slip
Good to know. If my car starts surging Iwill know where to look. When I first read the no power brakes and surging from 1000-4000 i was wondering what in the heck could the problem be.
Good job figuring it out. Have fun with the oil sending unit, I was once told swearing at it intimidates and makes working on cars easier...
Old Dec 21, 2001 | 11:30 PM
Drew's Avatar
Why do you guys make a simple repair into such a big problem? Seriously, the sending units for guages are ~$15, they aren't tight at all, I seem to remember I used a standard combination wrench to turn it a 1/4 turn to break it loose then turned it by hand till it was out, I covered the hole with my thumb and screwed the new one in, I lost maybe 2-5 drops of oil. The new sending unit was already prepped with a thread sealer. It was a 10 minute job including jacking up the car and finding a wrench the right size.
if there is one good thing I can say about the 2.8 and 3.1 cars its that they're easy to work on.
Old Dec 22, 2001 | 12:16 AM
Engine: 5.7 / 7.4
easy to work on?! those lower intake manifolds can be a b*tch to take off!!!!!!!
Old Dec 22, 2001 | 05:28 PM
drew, no offense or nuthin bro
i'm a beginner, and i admit that
i also have a very bad temper and anxiety problems, which means when my car breaks down, i go psyhcotic
just telling you the truth dood
call me stupid like you did b4, it aint gonna make me any smarter
Old Dec 23, 2001 | 01:35 AM
Drew's Avatar
My point isn't to make anybody feel stupid, cause everyone needs to start somewhere. But at the same time there is no reason to make a project harder than it has to be. Its good that you got it done and it works now, but its bad that this thread makes changing this sensor sound like a nightmare to everyone that reads it when its really a straight forward job.
The MPFI V6 is easier to work on than virtually any other engine offered int he Fbody. At least you can get at the bolts to tear the car down.
Old Dec 23, 2001 | 10:11 AM
KED85's Avatar
What about those Superb Access FOUR CYLINDERS!
I found one in the wrecking yard.
And a previous neighbor had one, too.
My Vega engine looked bigger!
Navy8125
Aug 21, 2015 09:32 AM
355sbcTPI
Aug 19, 2015 04:38 PM
bjpotter
Aug 12, 2015 06:06 PM
drathaar907
Aug 6, 2015 04:20 PM
antares57
Aug 6, 2015 07:47 AM
