IN SERIOUD NEED OF ELECTRICAL ADVICE!!!!
Old Apr 1, 2016 | 03:10 PM
MyNasty91's Avatar
Car: 91 RS Camaro
Engine: 3.1 in the begining and now a 5.7
Transmission: 700r4 w/ 2500 stall
I have a 3.1 that is throwing a E.S.T code. I had the ICM tested and just replaced the pick up coil. The ICM tested good. Where do I go from here. It has new plugs,wires, rotor, cap and button. IIt's all B.W.D parts not any performance just stock parts because I will be swapping motors soon but need to get this v6 running for now. PLEASE HELP. IM AN ELECTRICAL IDIOT!
Old Apr 7, 2016 | 09:14 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: IN SERIOUD NEED OF ELECTRICAL ADVICE!!!!
Are you positive the code is 42 and not for the ESC (knock control) system? If it is, you need to check the resistance of the tan/black wire between the ECM and the ignition module, making sure the "set timing" bypass connector is connected by the heater blower.
Makaveli88
Mar 27, 2016 01:21 AM
LeeH
May 7, 2001 08:25 PM
chris83z28
Mar 23, 2001 04:02 PM
Mike '91 Z28
Jan 3, 2001 06:08 PM
David Trimble
Jul 28, 2000 03:48 PM
