3.1 Oil pressure
Old Jun 1, 2016 | 06:24 PM
maroe624's Avatar
Car: 92 Z28 Clone
Engine: Vortec 350
Axle/Gears: 3.23 Torsen
3.1 Oil pressure
I have a problem were my oil pressure guage doesn't rise when giving it gas. it just stays solid on the first of the three lines to the right. With ignition on, motor off, it stays at the L mark. What could be the problem? Its a 3 wire sensor.
Old Jun 3, 2016 | 12:48 AM
inkscape's Avatar
Car: '91 Chevy Camaro RS
Engine: 3.1L LHO V6
Transmission: Borg Warner T5
Axle/Gears: GU6 3.42 Open Diff
Re: 3.1 Oil pressure
Have you attempted checking that power is going through the connector? Is it leaking oil through it? I just took mine out recently as oil was going right through the sender and connector... dripped all over my Y pipe. Now it constantly burns the same old damn oil on the pipe. I replaced my oil pressure sender with a aftermarket oil psi gauge and a copper tubing kit from Equus.
Matthew1821
Apr 23, 2016 03:44 PM
chevyguy1999
Apr 13, 2016 07:36 AM
thomashearts
Carburetors
Apr 10, 2016 03:14 PM
oners2nv
Apr 2, 2016 08:51 PM
utfan01ss
Mar 17, 2016 02:47 PM
