Hybrid swap ?'s
Old Jun 2, 2016 | 09:56 AM
Wafflestomp's Avatar
Car: 1987 Camaro, 1984 Camaro Berlinetta
Engine: cammed 2.8, turbo 3.1 hybrid
Axle/Gears: 3.42 one tire fire
Hybrid swap ?'s
I went through fast eddis post for a hybrid swap and I have a few questions if i run stock pistons with the 3400 heads what will the compression ratio be I dont have a cherry picker or engine stand at the moment so I cant pull my motor to change out pistons. And what its a good after market ecm thats easy to tune I am putting turbos in so Its a must
Old Jun 2, 2016 | 11:01 AM
camaroyoungster's Avatar
Car: 1985 Camaro Sport Coupe
Engine: Chevy 3.1
Re: Hybrid swap ?'s
I am pretty sure 2.8's have the flat top pistons in them so paired with FWD heads you are going to have a very large compression ratio. Something in like 11-12 range which will not work with pump gas. ECM wise, There are many options, EBL Flash and Megasquirt is a big one that a lot of people use too.
Drew
Old Jun 2, 2016 | 11:03 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
Re: Hybrid swap ?'s
Your compression will be something like 13:1 or 14:1, so too high to run on pump gas N/A. You DEFINITELY can't boost it with compression that high. You may want to look into renting a cherry picker and you can buy an engine stand for under $100. Megasquirt is an option or you can tune your existing ECM like others have done in here by burning your own chips.
Old Jun 2, 2016 | 12:03 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Re: Hybrid swap ?'s
Double post.. sorry
Old Jun 2, 2016 | 12:06 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Re: Hybrid swap ?'s
You would be best to run e85 of you are planning on using the rwd pistons.
For me with a 3.4l rwd block and small dish pistons .040 gasket and 3400 heads I would have 12.68:1 compression. Not bad really if I use e85 but pump gas.... would be tough and definitly couldn't boost it without e85 or race gas (100 octane or higher)
As for a ecm. I know alot have had sucess with the megasquit. I personally like my 7730 stock ecm. You could swap in the stock 7730 out of a speed density car truck and tune that with moates equipment if you wanted as well.
Old Jun 2, 2016 | 12:10 PM
Re: Hybrid swap ?'s
I figured the compression would be some where around how do I burn my ecm?
Old Jun 2, 2016 | 12:23 PM
drdave88's Avatar
Engine: 6.0L
Re: Hybrid swap ?'s
You'd have to start doing your homework in the PROM burning forum and on here. I looked into some of that, but never actually got to do it before I went V8. Or you can contact some other guys who have done it, they may be able to help or even get you a chip with a base cal to get you up and running.
Fasteddi (see above post) would be a good guy to talk to. Sorry to throw you under the bus Fasteddi
Old Jun 2, 2016 | 12:45 PM
Re: Hybrid swap ?'s
Cool thanks any suggestion on what tuning software to use
Old Jun 2, 2016 | 02:08 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Re: Hybrid swap ?'s
If you went the 7730 ecm swap route you would use tunerpro rt. It's free unless you register it.
If you did a megasquirt ecm you would use other software. I've never used it or played with Ms so I'm no help but a few on our v6 forum have.
When I get home I can toss together the bare bones list of what you would need for the ecm tuning and the ecm itself of you want.
Old Jun 2, 2016 | 02:10 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Re: Hybrid swap ?'s
Its no problem man. I'm not the best but I can definitly guide him if he wants to go that route.
Old Jun 3, 2016 | 06:25 AM
Re: Hybrid swap ?'s
Sounds good thanks
Old Jun 3, 2016 | 07:08 AM
fasteddi's Avatar
Car: 1991 Camaro RS
Re: Hybrid swap ?'s
Sounds good thanks
OK I'll get ya a list
Also if you need any hybrid stuff let me know I have about 3 whole set ups now and need to get rid of some to fund my newest project
Old Jun 3, 2016 | 12:58 PM
Re: Hybrid swap ?'s
How much for everything for the swap ie pistons heads intake ignition ect
Old Jun 3, 2016 | 03:09 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Re: Hybrid swap ?'s
Ill pm you about the parts.
heres a list of moates stuff you would need. This is the bare minimum of stuff. But its what ive been using now for over 4 years. I used it alot and i have got every penny of tuning out of it.
Moates is a very good spot to get stuff. They usually toss in instructions for the stuff they sell and also have help areas on there web site so that the installation of any of there stuff is a breeze.
gp1 package ($55)
http://www.moates.net/burn2-chip-pro....html?cPath=94
burn2 chip burner ($85)
from aldlcable.com ($60)
aldl cable 12 pin usb
http://aldlcable.com/products/aldlobd1u.asp
Then you would have to down load tunerpro rt off there web site and get some files from there or other places which we could help you out on. So minus a laptop which you would also need for datalogging, your arround 200 bucks to tune your car as many times as you want. I would strongly advise a Wideband o2 kit though to do tuning the right way. Thats adds another 150-200 bucks depending on what one you decide to go with.
Old Jun 3, 2016 | 05:03 PM
Re: Hybrid swap ?'s
gp1 package ($55)
Awesome man thanks thats very helpful
philmcgroin
Exterior Parts for Sale
Mar 28, 2016 02:13 PM
89 formula TPI
Mar 28, 2016 08:01 AM
CoryCDS
Mar 23, 2016 02:53 PM
DemonYusuke
Mar 22, 2016 03:42 AM
DemonYusuke
Mar 13, 2016 02:02 PM
