Base model idiot lights.
Old Jun 6, 2016 | 11:30 PM
Jokersall's Avatar
So from what I've read my base model firebird is very basic. Instead of having my amazing temp gauge I've been hunting for I have two rows of idiot lights. So a couple questions here. Does anyone know what all idiot lights are there? I've seen charging, oil, and brakes so far. I'm curious if I can't find small gauges to fit.
Secondly is there a place to add in another temp sensor for a new gauge or are there wires I can tap in to?
Old Jun 7, 2016 | 05:55 AM
SOHC-FTW's Avatar
Car: 86 T-top firebird/Black Dodge Ram
Engine: 2.8
Transmission: Automatic
Axle/Gears: 4.10s soon enough
Re: Base model idiot lights.
There is a temp and check engine light or SES that's bout all I've seen in mine that I can add.
Old Jun 8, 2016 | 06:05 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
Not sure what all is involved, but have you looked in to swapping out your cluster for a different one with gauges? I'm not sure if the wire harness would need to be changed out or just swap the cluster.
Old Jun 17, 2016 | 08:58 PM
oldschool's Avatar
Car: 1985 Pontiac Firebird
Engine: 2.8 LB8 HO
Transmission: 700R4 with OD
Axle/Gears: 10 bolt 7.625 open-factory 3.42
The complete instrument panel harness needs to be changed on the Firebird. Unfortunately you cannot simply swap in the gauge cluster. There are several disscussion threads on this.
notrabies
Jul 29, 2016 09:39 PM
thomashearts
Carburetors
Apr 10, 2016 03:14 PM
Veaceonee
Mar 22, 2016 05:56 PM
Vinscully50
Mar 15, 2016 03:25 AM
Scorched1984
Mar 13, 2016 10:10 AM
