TomP's Major Tune-up PARTS HELP
Old Dec 26, 2001 | 04:45 PM
nj88v6's Avatar
Doing TomP's major tune-up list while changing out my head gaskets, but I need some help with choosing aftermarket parts.
Want to know what brands are good for replacement of:
Dist Cap/Rotor
Spark Plugs
Plug Wires
Any opinions would be greatly appreciated. Also should I change the ignition coil while i'm at it, and what coil should I get too if I should. Thanks.
Old Dec 26, 2001 | 10:23 PM
Joe_L's Avatar
Car: 1995 Z28
Transmission: Built 4L60E
Axle/Gears: 3.23's - Limited Slip
Tom will be proud to see you using his list...lol
I am a big fan on AC-delco myself as far as plugs go. I would say welds or AC-delco distributor, Try to avoid accel distributor's.
A tip when replacing the PCV vavle buy straight from GM, or AC-Delco. I bought an aftermarket one, and my car pumped out oil throught the front seal in the crank. well after I replaced the seal still pumped oil out so I put the old PCV back in and the Cheap *** aftermarket one caused me all this grief... so go cheap but not too cheap....
LT1Formula
20
Nov 14, 2015 12:02 AM
stalkier
Aug 21, 2015 01:54 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
