No Click, No lights, No Nothing
Old Jul 21, 2016 | 02:50 PM
Spyder_TheGamer's Avatar
Car: '92 Camaro RS 25TH Anniversary Edit
Engine: V6
Transmission: Manual
So I was coming home from work. Got out the car for a couple of minutes. Jumped in to leave and the car did not start. Nothing, no lights, no click. Took the battery to get checked, it was good. Alternator is new, starter did make strange noises sometimes before this. Will a bad starter make it seem as if my battery just vanished, abducted by aliens or something? Someone please help your friendly neighborhood, Spyder-Man! The Spyder-Mobile needs help.
Old Jul 21, 2016 | 03:08 PM
Black_TA's Avatar
Car: 1983 Trans Am
Axle/Gears: Stock
Re: No Click, No lights, No Nothing
If you have no lights check all useable links and fuses, also check + and - battery wires.
Something is blown or wire fell off somewere.
Old Jul 21, 2016 | 03:36 PM
Engine: V6
Oklie doklie and thanks. I'm about to lift it up and check. Oh by the way, the Spyder-Mobile is a 92 v6 rs Heritage Edition. I know there is a fuse box underneath my steering wheel. I was told I should have one underneath the hood. But for my spider sense, I can't seem to locate this mystery fuse box under the hood.
Old Jul 21, 2016 | 04:21 PM
thtanner's Avatar
Car: 1989 Pontiac Formula 350
Axle/Gears: BorgWarner 3.27 Posi
Fusible link by the starter can fail causing this. Feeds power to most of the car. Think the same goes for the v6?
Old Jul 21, 2016 | 04:26 PM
Engine: V6
Thank you all, you all are my team of Avengers. I'm feeling better, was thinking I was going to have to let my baby go.
9192camaro
Mid-Atlantic Region
22
Jan 17, 2017 11:02 AM
IroczFan
Apr 30, 2016 04:50 PM
162chevy
Apr 26, 2016 02:09 PM
SethMorris
Apr 24, 2016 07:23 AM
generalchase
Apr 23, 2016 06:18 PM
