2.8 auto to manual swap
Old 10-08-2016, 01:51 AM
SteelheadBen's Avatar
Car: 1988 Camaro RS
Engine: 2.8L v6
Transmission: 700r4 stock?
Axle/Gears: peg leg one tire fire
Hello everyone. I have a few questions about a swap i would like to do.
So far i am on my second 700r4 transmission. Its starting to slip badly, so i figured this would be a perfect time to research a manual swap. I have found a few cars within my area that could be a good start.
My first question is will parts from a 1994 3.4L camaro be compatible with the 2.8 motor? (t5 transmission, pedal assembly, flywheel, etc.
Or will i have to use a 82-92 v6 parts?
The only reason I ask is there is a 94 camaro being parted out in my area cheap. Otherwise I need to travel a good distance for a 82-92 manual v6 parts car.
Thanks!
Ben
Old 10-09-2016, 07:34 PM
Gfunkill's Avatar
Car: Sport Coupe
Engine: 3.4 MPFI
Transmission: WC T5
Re: 2.8 auto to manual swap
easiest way to tell would be to look up the part numbers for a 2.8 vs a 3.4. I think everything will work.
When it came to the pedals, I am lazy and didn't want to swap the gas pedal, so I cut that off of the 3.4 manual pedal assembly. It works fine for me.
Old 10-10-2016, 10:51 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
The spline count is different on the 4th gen T5 trans. See the 6th post in the link below.
https://www.thirdgen.org/forums/tran...ything-we.html
Old 10-10-2016, 07:08 PM
Gfunkill's Avatar
Car: Sport Coupe
Engine: 3.4 MPFI
Transmission: WC T5
well there ya go
Old 10-11-2016, 01:21 PM
project89's Avatar
iirc u can use the 4thgen trans with a different clutch disc
Old 11-27-2016, 12:33 AM
Car: 1988 Camaro RS
Engine: 2.8L v6
Hello everyone, figured id bump this thread. I missed out on the opportunity to get the 4th gen t5, but now i have an opportunity to get everything from a third gen parts car.
I can get everything I need to do the swap for $400. The parts car is a 1992 3.1 t5 and im swapping that transmission in my 1988 2.8 700r4 car. The $400 includes the transmission, driveshaft, pedal assembly, clutch, flywheel, ecu, shifter plate, and the manual center console.
is there anything else i need to get from this parts car to complete my auto to manual swap? Also, will the t5 from the '92 use the same speedo gear that was attached to the 700r4 transmission?
