Cylinder head replacement???
Old Oct 9, 2016 | 06:17 PM
maroe624's Avatar
Car: 92 Z28 Clone
Engine: Vortec 350
Axle/Gears: 3.23 Torsen
I need a new pair of cylinder heads on my 92 3.1 due to exhaust manifold bolts broken off. What do I need to take into account before doing the swap? Can I use same pushrods? Lifters? I will be getting a pair off a 3.1 or 3.4.
Old Oct 9, 2016 | 06:22 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Re: Cylinder head replacement???
You could just drill out the broken studs. But all gen 1 60 degree V6 heads are the same, so any parts external to them will be able to be used.
Old Oct 10, 2016 | 12:19 AM
maroe624's Avatar
Car: 92 Z28 Clone
Engine: Vortec 350
So should I use the pushrods from the donor car or my car? All I would have to do is set the valve lash right? What about lifters?
Old Oct 10, 2016 | 05:05 AM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
As long as you are using Ironhead it does not matter with pushrods you use.
As for lash. You tighten down till you reach zero lash. That's where you can just barely feel resistance when spinning the pushrod then tighten the bolt a additional 5/8 to 3/4 of a turn for the preload on the lifters. I always went with 5/8ths.
Always be sure that the valve you are lashing in is closed!!!
Old Oct 11, 2016 | 01:24 PM
project89's Avatar
http://www.ebay.com/itm/GM-2-8-3-1-3...JWfElo&vxp=mtr
be sure to use new head bolts , and u need to run a tap threw the holes on the block to clean the threads or u wont get proper tq readings
Alaska Hwy 1Le
Jan 2, 2017 04:30 PM
billybob6110
Sep 27, 2016 06:04 AM
billybob6110
Sep 26, 2016 06:37 AM
UltRoadWarrior9
Sep 23, 2016 06:38 PM
whyt86roc
Sep 14, 2016 08:59 PM
