Need help 91 Camaro RS
Old Dec 20, 2016 | 03:07 PM
Nelscz's Avatar
91 Camaro starts only when coil wire is unplugged from distributor when I plug it back in it dies already changed plugs wires cap rotor and coil
Old Dec 20, 2016 | 03:52 PM
OrangeBird's Avatar
Car: 1989 Firebird
Re: Need help 91 Camaro RS
Sounds like the ignition timing is too far advanced (early) if I had to take a blind guess .
The reason I say that is because unplugging the coil wire like your doing is adding all the more gap for the spark to jump , with the net result of delaying (or retarding if you will) the actual time in the cycle where the plug lights the fire .
Try retarding (late , delaying) the distributor timing somewhat and see if it'll run with the wire plugged back in . If so , next do the proper timing procedure where you unplug the advance line and set the base timing , and see if it still runs with the coil plugged back in .
Old Dec 20, 2016 | 03:53 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
SO you are saying when you have no coil wire from the coil to the top of the dizzy and it runs????? Now im confused....
Old Dec 20, 2016 | 05:47 PM
OrangeBird's Avatar
Car: 1989 Firebird
I was taking his post to mean that he has the wire slightly pulled out , but still close enough for the spark to jump the gap . If he meant that it ran with the wire far enough away for there to be no connection whatsoever then yea , he'd need an Exorcist rather than any possible advice we could give him ...
