Fan staying on once cut in?
Car: 1984 Firebird S/E
Engine: 1985 2.8 MPFI
Transmission: 1985 T5 5 speed manual
Axle/Gears: 3.42/4.03
Hey everyone.
Had a mishap the other day when a live wire touched the body of the car for around 3 seconds and now once the fan has cut in it won't stop. Any ideas?
cheers
Rich
cheers
Rich
Car: check
Engine: check
Transmission: check
Re: Fan staying on once cut in?
What wire was this? Sounds like the fan relay is sticking. Once the engine cools enough that the fan should stop, tap on the fan relay. If the fan stops the relay is bad.
RBob.
RBob.
Thanks RBob. It was a wire I'd added for a function and had stupidly wired to +12V before I'd attached the other end, my own fault.
It seems to have sorted itself out after I checked all the fuses and replaced the slightly melted gauge fuse, which is where I took the feed from.
but it now really doesn't like starting once it's been run. One thing after another with this car!!
