Broken Rocker arm in 3.1 what will fit?
Old Mar 26, 2017 | 07:56 PM
DEVILPUP's Avatar
Car: 92 Camaro
Engine: 3.1 v6 (building lt1)
Transmission: auto
I had some upper engine noise that started after I pulled the Camaro out to get ready for summer. 3.1v6
Pulled the valve covers
Number 1 intake rocker had made a perfect hole in it's self on the spring side of the rocker arm and was loose as well.
pushrod is nice and straight and the spring looks undamaged as well
I have a set of 97 lt1 heads with all the valve train in good order
can I pull a rocker of the LT1 ? or do I need to go digging in the local pullaparts lot?
thanks for any help team
Old Mar 26, 2017 | 11:46 PM
GeneralDisorder's Avatar
Re: Broken Rocker arm in 3.1 what will fit?
Does not look like those will cross. Seems to be a V6 specific part number. They are super cheap though. Inspect the others and replace any that show wear. Had a rocker blow out on my truck's 350 a few years ago - not rhyme or reason to it. Just happens sometimes:
http://www.rockauto.com/en/catalog/c...ocker+arm,5656
Rick
