Broken PS bracket due to belt being too tight?
Old May 17, 2017 | 01:04 AM
maroe624's Avatar
Car: 92 Z28 Clone
Engine: Vortec 350
Axle/Gears: 3.23 Torsen
Well my power steering bracket broke off and i think its cause my belt tension is too tight. Is there a way to loosen the tension a bit? My 3.1 has smog pump and ac compressor delete. its broken before but the other bolt that bolts into the head held it in place. i switched out the broken bracket but this time the bracket snapped and the bolt that bolts to the head also broke off the head so i have to extract that bolt. So once i extract the bolt that goes to the head and get a new bracket on there im wondering if theres a way to loosen the tension a bit so the belt wont be soo tight so i can avoid another broken bracket.
peep
Old May 17, 2017 | 02:13 AM
maroe624's Avatar
Car: 92 Z28 Clone
Engine: Vortec 350
Re: Broken PS bracket due to belt being too tight?
just did some digging and seems i need the rear steel brace that goes behind the ps pump to header. anyone have one let me know. im gonna try the junkyard.
Old May 17, 2017 | 12:49 PM
maroe624's Avatar
Car: 92 Z28 Clone
Engine: Vortec 350
Can somebody send me a pic of the bracket behind the power steering pump. I cant seem to find a pic of what it looks like. Or anybody have an idea on how I can reinforce the power steering pump so it wont break on me again. Thanks
Old May 17, 2017 | 02:54 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Number 26 in the pic, looks like a stamped steel piece....
RBob.
Attached Thumbnails Broken PS bracket due to belt being too tight?-camaro_ps-mount_2540a.jpg
Old May 17, 2017 | 03:02 PM
maroe624's Avatar
Car: 92 Z28 Clone
Engine: Vortec 350
Dam it looks like that bracket goes on the exhaust manifold stud and mine doesn't even have the stud dam. That's another problem I have . Do you have an actual picture? seems like that bracket is out of the question.If i do find the bracket maybe it will hold with just the bottom bolt. I need to find another way to reinforce that bracket dam.
