extreme leaning out in open loop... need ideas
Old Feb 8, 2018 | 08:06 PM
morrow's Avatar
Car: 92 Camaro Rs.R
Transmission: wc t-5
ok guys
i had bean beating my head against a wall for a week
the car runs great while its cold. once it gets to running temp, it leans way out
i have a afr gauge running off of the coputer innput from the o2 and it will idle fine but the moment you get over 1400 rpm it leans out and falls on its face(only after it warms up)
help me lol
Old Feb 9, 2018 | 02:24 PM
morrow's Avatar
Car: 92 Camaro Rs.R
Re: extreme leaning out in open loop... need ideas
Nobody?! Lol
Old Feb 9, 2018 | 02:29 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Only think I could think of is maybe slightly clogged injectors. Or leaking injectors and the ecm is overcompensating for a rich condition.
Old Feb 9, 2018 | 08:38 PM
LiveIt!'s Avatar
Car: 1988 Camaro Sport Coupe
Engine: The All-Powerful 2.8l!! :P
Stock 3.1 Multec injectors? I'm running them in my car and funny things definitely happen when the car's warm, I'll sometimes get a volt drop, and some engine noise. I think my issue is they're causing a rich condition tho, not lean, but still something worth checking out
Old Feb 10, 2018 | 08:12 PM
morrow's Avatar
Car: 92 Camaro Rs.R
yea i pulled the injectors and they ohm out to 11.5 to 11,9
not leaking but possibley cloged
put them back in and changed temp sender tps iac cap rotor wires and ignition mod
it needed a tunr up anyway
runs and idles nicely now, though very long crank befor starting and the moment i hit the throttle its leaning out
im thinking its the injectors as well .. there the oem injectors by the way
Old Feb 11, 2018 | 10:36 AM
OrangeBird's Avatar
Car: 1989 Firebird
I have a question that maybe Tuned Performance can answer ?
My question is this ;
Could the fact that he has a AFR gauge hooked up to the same place on the ECM that the 02 connects to be causing the ECM to see a faulty 02 reading from the gauge "loading" the 02's output signal down lower than the ECM expects to be seeing ? I only as because I know the 02 deals with a pretty tiny voltage swing through it's operating range and I have no real clue as to whether such loading would be relevant to it or not ....
Old Feb 11, 2018 | 10:52 AM
Engine: Lb9
Transmission: M20
I don’t think it’s a problem sharing the o2 signal.
Old Feb 11, 2018 | 11:11 AM
morrow's Avatar
Car: 92 Camaro Rs.R
i have been running the afr gauge off of that signal forabout 6 years without an issue so i doubt thats it
Old Feb 11, 2018 | 11:14 AM
morrow's Avatar
Car: 92 Camaro Rs.R
illchange the injectors next, i was looking at the bosch 4 or 2 hole injectors.. any tips?
the car is running pacesetter headers with a custom intake as well as the prom has bean sent out and re programmed to work with the headers and intake ..
i have been running this set up on the oem style injectors for about 7 years or so
Old Feb 11, 2018 | 11:37 AM
Engine: Lb9
Transmission: M20
You might want to ask the experts southbay08 for injector options.
https://www.southbayfuelinjectors.co...85-1992_1.html
Old Feb 11, 2018 | 12:55 PM
OrangeBird's Avatar
Car: 1989 Firebird
Thank You for the answer , it was just a passing thought that I had no real clue about so I figured I'd ask someone who knows .
pandin
Sep 11, 2008 09:25 AM
Z-BOSS
Apr 10, 2001 10:35 AM
