EGR Vacuum Switch help
Car: 88 Sport Coupe Camaro
Engine: V6 2.8
Transmission: Borg-Warner T-5
Axle/Gears: RPO/GU6: 3.42
Re: EGR Vacuum Switch help
Does it have to be exact replacement?
Can you measure the voltage coming from the ECM when the circuit is active, and substitute a different switch/solenoid that operates at that voltage?
All this gizmo does is allow vacuum to pass to the diaphragm in the EGR valve when voltage is applied to the gizmo, right?
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
You can have a parts store see if standard motors vs16 is the correct part for you.
http://mybaycarparts.com/Standard-Mo...-P2081747.aspx
djmarch
May 15, 2015 04:22 PM
88TransAmFreak
Jun 2, 2009 09:34 PM
86TpiTransAm
Nov 27, 2001 07:18 PM
