Starting a 91 that sat for 16 years.
Car: 1991 camaro RS
Engine: 3.1l
Transmission: auto
Title. I bought a 91 camaro that sat for 16 years. Got the electrical system running. Got new oil and oil filter. Aside from new gas, what do I need to do to make it turn over? I'm looking for engine problems. I'm not gonna drive it around, just make sure it turns over.
Assuming it turns over, what do I need to replace to make it run good? I want a list, if possible, of everything that can go bad, and I'll replace it. So far, I have the following:
All fluids(brake, oil, ATF, windshield wiper, coolant)
Tyres
Thermomiter right next to throttle body
Shocks
All weather plastics
All caps to important systems(radiator cap, oil fil cap, etc.. They'll ALL bad)
Steering wheel(previous owner broke it)
Tank(Maybe. How do I know if its bad?)
Oil filter, fuel filter, transmission filter(I don't know if 91s have these, they should in the pan, right?)
New gas and siphon old gas
New spark plugs
New battery
Shocks are in extremely good condition.
Is there anything else I need to check before I start driving it? Anything I need to do before I attempt to turn it over?
Thanks so much --
Jarad
PS: If this is the wrong subforum point me towards the right one please
Tyres
Shocks
New spark plugs
New battery
Thanks so much --
Jarad
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Starting a 91 that sat for 16 years.
I’m sure you will be looking at a new fuel pump and probably injectors.
Car: 1987 GTA
Engine: 5.0
Transmission: Automatic
Mine sat in a field for 11 years roughly, here is what was done to mine. Dropped tank and cleaned, disconnected fuel lines at intake and blew them out, new pump and sending unit. All new injectors (tpi), replaced all manifold gaskets, new plugs,wires,rotor button,cap, and ignition control module, drained radiator and replaced coolant,new thermostat, changed oil and filter, put a hot battery in and fired it up. Once it was running good it got all new brakes, front bearings, changed differential fluid, atf and new filter, new suspension bushings, and I forgot to mention a new air filter. I will advise you if the fuel tank is nasty I recommend replacing it when you do your pump if you have too. I will be dropping mine tomorrow and putting a new one in. You can probably skip a lot on my list and replace things as needed but I went on with the thought of getting it all done on the front end rather than later. If yours was stored inside that is a big plus. Joined: Jan 2009
Car: 94 Camaro
Engine: 3.5 turbo
Transmission: Performabuilt 4l60E
Axle/Gears: Strange rear, 3.42
All vacuum lines, pcv valve, egr valve and most important the condition of all brake lines.
Car: 1998 Camaro Z28
Engine: 6.0L
Depending on where it sat, you'll want to look for damage to wiring from mice/rats/etc chewing on it.
Car: 88 T firebird
Engine: 2.8
Transmission: t5
Camaroguy18
Jun 12, 2011 10:51 PM
SSZ2891
Mar 31, 2010 09:00 PM
iroczrockz
Aug 19, 2007 02:38 PM
