Oil Pressure Gauge - Dummy to Actual
Old Jul 3, 2018 | 11:27 AM
cooltc2004's Avatar
Car: 1992 Firebird
Engine: 3.1L V6
Transmission: 5 Speed Manual
Axle/Gears: 3.42 Peg Leg
I know I've found the answer before, but I haven't had any luck in the search bar. My Firebird came stock with the dummy oil pressure gauge. I've since swapped in one with an actual reading, but I wanted to get it to read correctly. What is the proper way to accomplish this?
Old Jul 3, 2018 | 12:36 PM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
Re: Oil Pressure Gauge - Dummy to Actual
Electric oil pressure sensor wire to gauge. Likely a sensor for the idiot light already there so unscrew that screw in oil pressure sensor connect to input side of gauge. The sensor is at the back of the engine near the distributor and to right.
Old Jul 3, 2018 | 12:52 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Are you saying you switched from a idiot light to a gauge. Or you are running a aftermarket gauge ?
I believe the 3.1l sender is on the side of the block (maybe bye the oil filter)but if someone who knows chimes in.
Old Jul 3, 2018 | 01:00 PM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Sorry thought we were talking v8 here there is another thread on this subject under new posts.
Old Jul 3, 2018 | 01:45 PM
cooltc2004's Avatar
Car: 1992 Firebird
Engine: 3.1L V6
stock gauge, I took apart my cluster and put in the actual oil pressure gauge.
Similar to this:
So will simply swapping the sending unit work?
Old Jul 3, 2018 | 01:51 PM
Engine: Lb9
Transmission: M20
Sounds like you just need to swap the sender for one intended to operate a gauge not light.
https://www.rockauto.com/en/catalog/...+/+switch,4588
Old Jul 3, 2018 | 01:58 PM
Engine: Lb9
Transmission: M20
You might need this as well
https://m.autozone.com/test-scan-and...ket/141490_0_0
Old Jul 3, 2018 | 02:22 PM
cooltc2004's Avatar
Car: 1992 Firebird
Engine: 3.1L V6
Thanks Tuned Performance for the help.
Is the ACDelco P/N for this sensor 19244498 ? Do you know by chance?
Old Jul 3, 2018 | 02:31 PM
Engine: Lb9
Transmission: M20
That one is for a v8 the thread size might be the difference.
http://parts-catalog.acdelco.com/cat...parttype=13795
Old Jul 3, 2018 | 02:36 PM
Engine: Lb9
Transmission: M20
Not positive. It I think it’s acdelco 19244497
It’s odd the application listing says 91 Pontiac but not 92
And shows for v8 as well.
Old Jul 3, 2018 | 03:06 PM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
You will probably have to hard wire direct to gauge it self since factory plug in is not likely active for oil pressure gauge since you had a dummy in there.
Old Jul 3, 2018 | 03:12 PM
Engine: Lb9
Transmission: M20
It should have a blue wire for the ops signal running through c100 onto the gauge. It also is the switch for the fuel pump and would contain two orange wires or a orange and grey wire. So if there is any differences it would be in the instrument panel.
XxXChrisGXxX
Interior Parts Wanted
May 18, 2012 11:34 PM
Base91
Oct 13, 2011 05:14 PM
safemode
Feb 7, 2005 07:26 AM
onedownpaul
Nov 25, 2003 10:08 PM
