fuel in intake
Old Jul 22, 2018 | 01:35 PM
shaake's Avatar
fuel in intake
92 camaro 3.1 the car died "friday" at the light then after restart, had to keep the throttle up, went bak to the shop, turned it off, looked under the hood, restart and ran fine, started home and it started losing power and again had to feather it. stopped and parked, stayed running but loped well under normal rpm, turned it off, and cant start it, found fuel when i pulled the intake hose off the throttle body. ?? new coil and plugs thus far
when turning it over, its not trying to start at all,
Old Jul 22, 2018 | 01:43 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: fuel in intake
Did you check for spark ?
Old Jul 22, 2018 | 01:49 PM
shaake's Avatar
Re: fuel in intake
yes, before anything i checked with a bad plug in the wire and got a pretty good spark
OrangeBird's Avatar
Car: 1989 Firebird
Re: fuel in intake
Your fuel pressure regulator has failed , that's the only way you can get fuel into that part of the intake system (which normally is supposed to have nothing but air in it)
Old Jul 22, 2018 | 01:52 PM
Engine: Lb9
Transmission: M20
Re: fuel in intake
Iirc you can use a fpr from a tpi.
https://www.rockauto.com/en/catalog/...regulator,6124
Old Jul 22, 2018 | 01:56 PM
shaake's Avatar
Re: fuel in intake
this is what i was thinking too
Old Jul 22, 2018 | 10:03 PM
Drew's Avatar
Re: fuel in intake
Pull the vacuum hose off the fuel pressure regulator, turn the key on, look for gas squirting out of the regulator. You might have to cycle the key on/off a few times, but if you don't get fuel spraying out, the regulator might not be the problem.
Old Jul 24, 2018 | 12:49 AM
HellHound's Avatar
Car: I drive trans am. Duh
Engine: Yes, I have one in the trans am
Transmission: I have one of those too In trans am
Axle/Gears: In the rear of trans am
Re: fuel in intake
I just got doing mine. I was dreading it. But took like 20 minutes to do. I used the tpi fpr. And you need a security torx bit for it. Also you could install a adjustable fpr for a tpi while in there. I am going to.
Old Jul 24, 2018 | 02:29 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
Re: fuel in intake
Just did my fuel pressure regulator.
Part number for TPI and 2.8 is the same!
kirkcomer
Aug 18, 2017 10:05 PM
Arctic White 91 RS
Aftermarket Product Review
Feb 28, 2017 06:35 AM
skinny z
Alternative Port EFI Intakes
20
Feb 21, 2017 10:48 AM
oil pan 4
Carburetors
Jan 21, 2017 01:29 AM
slowTA
Nov 19, 2016 08:07 AM
