Help with back firing and running rough.
Old Oct 30, 2018 | 07:14 AM
Grandpa's Avatar
Car: 1990 Camaro RS 3.1L
Engine: 3.1L v-6
Transmission: 200R4
I have a 1990 3.1 mpfi and I had a timing chain that had gotten slack in it so changed it. Well then I have a back firing through intake and exhaust. Got the intake one to stop but still have the other. all ignition parts are new dist wires plugs. the only electrical components from one end to the other that have not been changed is the o2 sensor and the map sensor. It runs rough popping through out the rpm range. When I park it and get back in to back out it keeps dying and smells like it's flooding. I did find a problem with the secondary are valve was letting air go both ways all the time, eliminated that still same problem. Help I don't have a lot of money to just buy parts.
Old Oct 30, 2018 | 10:31 PM
maroe624's Avatar
Car: 92 Z28 Clone
Engine: Vortec 350
Axle/Gears: 3.23 Torsen
Re: Help with back firing and running rough.
Check your timing .
Old Oct 31, 2018 | 08:09 AM
Grandpa's Avatar
Engine: 3.1L v-6
Transmission: 200R4
Timing keeps moving I set it it changes after a few miles.
Old Oct 31, 2018 | 03:50 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Are you setting it with the est disconnected ?
Have you ohmed out the injectors?
Old Oct 31, 2018 | 07:21 PM
Grandpa's Avatar
Engine: 3.1L v-6
Transmission: 200R4
Yes est is disconnected , no can't get to the injectors to check them. I just cleaned them a little while back right before the timing chain was installed. I had the intake off replacing gaskets that where leaking oil.
Old Nov 1, 2018 | 05:28 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
If your timing is moving, you may have wear in the distributor. How much does it move from when you set base timing (10 degrees), to when you check base again?
Old Nov 2, 2018 | 07:23 AM
Grandpa's Avatar
Engine: 3.1L v-6
Transmission: 200R4
It is a new Distributor, I changed the O2 sensor and it corrected the timing issue. Runs better not popping all the time but once in a while you hear a pop in exhaust. I cleaned the IAC and it pocket it goes into Tweaked the TPS but pulles good in 1st but sluggish in 2nd 3rd is ok but still jumping between drive and overdrive a little too easy. Even on cruise.There is still the slight exhaust leak at the manifold and doughnut but Got to get more money to fix that and change the MAP sensor. Then every electrical part on the car will be new.
Old Nov 2, 2018 | 09:09 AM
Grandpa's Avatar
Engine: 3.1L v-6
Transmission: 200R4
I have an unrelated question. I have not cat and no smog pump haw can I delete the EGR and not mess the ECM up?
Old Nov 2, 2018 | 01:02 PM
Engine: Lb9
Transmission: M20
you will need to buy a programmer or have the code 32 and mat enable temp set to a maximum value.
tc http://tunercat.com/ or tunerpro http://tunerpro.net/ $88 definition.
Old Nov 2, 2018 | 05:44 PM
Grandpa's Avatar
Engine: 3.1L v-6
Transmission: 200R4
Thanks I'll have to wait till I can get more money together. Hopefully soon.
Old Nov 5, 2018 | 05:34 AM
drdave88's Avatar
Engine: 6.0L
You can delete the EGR without tuning, but you will end up with the check engine light on. EGR is only active at cruising, its shut off at accel, decel, open loop, etc. I made some block off plates and removed everything from mine. Never saw an issue with MPGs or anything. It won't "mess up" the ECM though. But yes the correct and complete way is to tune it out once it's been deleted.
Old Nov 9, 2018 | 05:58 PM
Grandpa's Avatar
Engine: 3.1L v-6
Transmission: 200R4
Well I found out today that the dang fuel filter was nearly clogged up with rust, go figure I cleaned the tank thoroughly when I changed the fuel pump. But that's what happens when they sit to much and not full of fuel. So I'll go drive it in the morning and see how much of the problem is corrected. I just dread the task of pulling that tank again but I'll go back with new tank sender as mine does not work and pump. Thanks guys for your help.
Old Nov 13, 2018 | 02:09 PM
Sierra6's Avatar
Car: 1985 Firebird
Engine: 3.4 turbo
that was my problem. we cleaned out the gas tank but we never could get all the rust out. had to redo the job with a brand new gas tank. wish I had converted to a 4th gen plastic tank.
RunawayRadio
Nov 22, 2016 12:13 PM
Camarofan1
Oct 27, 2016 06:08 PM
mike0brien
Oct 14, 2016 03:59 PM
L6969
Sep 25, 2016 12:34 PM
dr.watkins9
Sep 22, 2016 03:33 PM
