V6 vacuum test
Old Nov 12, 2018 | 03:27 PM
Firebird2011's Avatar
Car: Pontiac Firebird Formula
Engine: 3.1 LH0
Axle/Gears: Automatic
V6 vacuum test
As mentioned, how can I perform a vacuum test? I connected the hose of the tester as shown in the pic, am I doing all right? The tester measured about 7 psi, I think it’s too low!
Old Nov 24, 2018 | 05:49 AM
3.4 grape's Avatar
Car: 94 Camaro
Engine: 3.5 turbo
Transmission: Performabuilt 4l60E
Axle/Gears: Strange rear, 3.42
Re: V6 vacuum test
You should hook the vacuum line directly to the manifold with a single hose, no tee's. I'm not sure where that line goes to. Use a vacuum port that does not affect the running of the engine.You should have a vacuum gauge that reads to 20 hg . The one you have only goes to about 15 hg. Idle readings should be between 16 to 20 hg.
ShiftyCapone
LSX and LTX Parts
Nov 12, 2018 09:01 PM
