Pic of your power steering bracket.
Old Jan 24, 2019 | 09:43 PM
maroe624's Avatar
Car: 92 Z28 Clone
Engine: Vortec 350
Axle/Gears: 3.23 Torsen
Can someone post a pic of your power steering support bracket? The one that goes behind the power steering box and attaches to the manifold? Please thank you.
Old Jan 25, 2019 | 01:54 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Pic of your power steering bracket.
Tough getting in there, this picture shows most of it.
RBob.
Old Jan 26, 2019 | 07:41 AM
thirdchance's Avatar
Car: 1991 R7U Z28 1LE
Engine: LB9
Axle/Gears: G92 3.42 Truetrac
Old Jan 26, 2019 | 10:51 PM
maroe624's Avatar
Car: 92 Z28 Clone
Engine: Vortec 350
RBob.
Yup that's the one. I never had that bracket on my car and it was fine but I broke the power steering pump aluminum bracket several times and to remedy my problem I got a bigger belt to ease the tension on the bracket but after my trans rebuild it started vibrating a lot more, so I checked it out and turns out my power steering pump shakes real bad and when I open up the reservoir the fluid is splashing out and not steady. So the other day I was parking and dam I start hearing my power pump whine and saw fluid all over the ground . My high pressure hose unscrewed itself . Picked up the bracket today at a junkyard. Thanks for the pic bro. Gonna fix it the right way.
gtaguy87
OLD Third Gen Nationals
Sep 2, 2019 02:17 PM
Tony89GTA
Jul 1, 2010 06:53 PM
f355bird
May 5, 2008 11:45 PM
V6camaroman
Jul 7, 2002 02:04 PM
