What is an O2 Sensor
From: Mililani, HI USofA Search Posts: 2848.............. Whore Posts: 47.................. Magical Whore Posts: 1
Car: 91 Camaro 77K
Engine: 3.1 Vslick
What is an O2 Sensor?
What does it do?
Where is it?
Do you need it?
What does it do?
Where is it?
Do you need it?
an o2 sensor is a device that tells your computer how lean or rich your air to fuel ratio is so that your computer can adjust it to make it perfect (14.7 : 1) in our cars it is located just after the y pipe meets, and yes you need it
-Bruce
-Bruce
Car: 91 Camaro 77K
Engine: 3.1 Vslick
So it won't be affected if I replace / remove the Cat.
HoosierinWA
Oct 7, 2015 10:15 AM
