Intake, Non-CCC Carb, Vacuum Advance Distributor swap done but.............
Old Jan 9, 2002 | 08:59 PM
fiream's Avatar
Car: 1983 Pontiac Firebird
Engine: 400HP 350
Hey guys I finished swapping my stock intake for an edelbrock intake and non-ccc carb, and vacuum advance distributor. My one problem is the car is not starting. I think it maybe to advance because the is popping through the carb. Should I back the distributor a tooth or two? What else would not make it start. It's getting fuel, there's no clogs or anything. I don't know what do you think?
Attached Thumbnails Intake, Non-CCC Carb, Vacuum Advance Distributor swap done but.............-bigmess.jpg
Old Jan 9, 2002 | 11:58 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
double check that the distributor is alligned correct. Popping thru the carb is usually a back fire. Did you do the sparkplug wire test to see if it's getting juice?
What's with the rainbow color in the pic?
At least your heads look better than mine.
Old Jan 10, 2002 | 09:26 AM
fiream's Avatar
Engine: 400HP 350
I checked the plugs to see if they were getting spark and they are. I'm going to have to fiddle with the distributor alittle i guess. Oh yeah, what do youy mean by,
Where is it?
Old Jan 10, 2002 | 09:45 AM
Engine: 5.7 / 7.4
I think it's the a'c compressor, never mind.
Old Jan 10, 2002 | 10:04 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I wouldn't back the distributor off "a tooth", I'd just spin it clockwise a few degrees and try to start it, spin it back counterclockwise a few degrees and try to start it, etc. Did you install it at 0 degrees advance with the #1 (front pass side) cylinder at TDC? If so, spin the distributor counter-clockwise a bit to put some advance into the timing.
Old Jan 10, 2002 | 01:14 PM
Xenodrgn's Avatar
Sounds like timing... just play with it... usually intake backfire is too far retarded, so do like Tom said and advance it some...
Old Jan 10, 2002 | 08:56 PM
fiream's Avatar
Engine: 400HP 350
I'm almost there I advanced alittle and it almost wants to start, I should have it running by tommorow.
1992 Trans Am
May 10, 2023 07:19 PM
midge54
Jan 29, 2017 07:00 PM
86IROC112
Aug 17, 2015 02:00 PM
cstrobel65
Aug 15, 2015 10:19 AM
mustangman65_79
Aug 8, 2015 12:07 PM
