Help with choosing correct oil pump
Old Oct 18, 2019 | 02:11 PM
Iroc95's Avatar
Car: Camaro rs 1991, BMW e39, F11
Engine: V6 3.1
Transmission: 5 speed manual
Axle/Gears: Stock
Hello,
I have a hard time choosing new oil pump for my 3.1 v6 1991 camaro.
Numbers on my pump are 154, GM3177, 148, and 10118839 - that one could be 10118639
The standard volume / pressure pumps I find on rockauto are
MELLINGM134
Alternate/OEM Part Number(s): 10118640, 10229785, 10229787, 12593581, 8101186400, 89060444
ENGINETECHEP134
or even better if I could just buy rebulid kit for my pump:
SEALED POWER22451317
Use To Repair 224-4148 and 224-4152 Oil Pumps
MELLING K95B
Use To Repair M-95, M-95B, M134 Oil Pumps
The problem is that all producs are looking the same to me from the pictures, I`m not sure if everything would fit or not.
Also where does the white plastic bushing goes? I dont have that piece on my pump...
Thank you for anwsers
Old Oct 18, 2019 | 04:59 PM
maroe624's Avatar
Car: 92 Z28 Clone
Engine: Vortec 350
Axle/Gears: 3.23 Torsen
Re: Help with choosing correct oil pump
Originally Posted by Iroc95
Hello,
MELLINGM134
ENGINETECHEP134
MELLING K95B
Some oil pump shafts have a slit were that little white piece goes. Mine didn't. You can buy one with a slit. Helps keep the shaft from coming up out the oil pump. . Might as well get a new one as they wear.
Old Oct 19, 2019 | 02:49 AM
Iroc95's Avatar
Engine: V6 3.1
Axle/Gears: Stock
Thank you for anwser... I still don`t know if I can install any of mentioned oil pumps, do you know anything about this?
Old Oct 19, 2019 | 05:23 AM
3.4 grape's Avatar
Car: 94 Camaro
Engine: 3.5 turbo
Transmission: Performabuilt 4l60E
Axle/Gears: Strange rear, 3.42
The Melling pump is a good quality pump/ rebuild kit. You can check part numbers for your vehicle on their website, or just give them a call. https://www.melling.com/
Old Oct 19, 2019 | 05:34 AM
Iroc95's Avatar
Engine: V6 3.1
Axle/Gears: Stock
I will take their M134 pump 👌
Wyomaro
Jul 2, 2018 01:34 PM
anesthes
Feb 25, 2014 08:43 PM
welchk85
Apr 1, 2010 06:53 AM
el_muerte
Mar 12, 2010 06:28 PM
Waymores
Jan 27, 2010 04:21 AM
