Help locating this part
Old Jul 7, 2020 | 03:50 PM
Faolan's Avatar
3.1 mpi. Got a vacuum leak that pops up every now and then and I have to push this rubber piece back in. Where can I find one
Old Jul 8, 2020 | 09:41 AM
LarryD's Avatar
Car: 92 RS
Engine: 3.1 V6
Re: Help locating this part
You could try the Chev dealer but I doubt they will be able to find one for you. I had to replace mine due to damage to one of the tubes so had to go to a wrecking yard and pull one off a donor car. You could try a little grease on it to get it to slide in further and then use a tie wrap to hold it in place. I believe one of those "plugs" is a dummy plug (if I remember correctly) so you could put a little black RTV on that plug to hold it in place but that might be a problem if you have to take it apart again.
jaridjohn
May 5, 2017 05:44 PM
tri power
Jul 28, 2012 09:00 PM
tman1753
Sep 12, 2009 08:34 AM
Bobby_80s
May 23, 2008 12:54 PM
