finding a vacuum leak help
Old May 20, 2008 | 11:10 PM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
what can an auto shop do that i cant to find a vacuum leak?
on my 305 tpi theres so many wires and hoses in the way im not sure how I could possibly find a stupid vacuum leak because its most likely not in an obvious place
can I rent a vacuum tool that will tell me where the leak is?
or does a shop have specil equipment to save me the agrivation?
Old May 21, 2008 | 11:57 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
A shop can make money at it.
A vacuum pump/gauge like a Mity Vac (I'd just buy one if possible rather than try to rent it) can help you identify leaking components like EGR valve. It won't, most likely, help you fine leaking hoses, and certainly won't help you find leaking gaskets or leaking power brake booster.
Why do you think you've got a vacuum leak?
Old May 21, 2008 | 01:08 PM
doc221978's Avatar
Car: '81 Z-28
Engine: Soon to be a 383
Transmission: Muncie
Re: finding a vacuum leak help
I know it's not the safest method, but i always spray carb cleaner on areas where i think there is a leak. If it is leaking you will here a change in tone of the engine for a couple seconds.
Old May 21, 2008 | 01:29 PM
Bobby_80s's Avatar
Axle/Gears: no idea
cuz my idle is high, not eratic or searches just high
not sure if its my adjustable fuel pressure regulator just giving me more fuel than i need to give me more fuel the screw is barely touching inside
other idea is an air leak making me run alil rich and giving me high idle
Old May 21, 2008 | 05:46 PM
Nsomnia's Avatar
If you got one of those 1 liter propane torches, open it up and go around hoses, gaskets, brake booster etc. everywhere. Your engine should rev a tiny bit if it sucks some propane in.
Old May 23, 2008 | 12:54 PM
doc221978's Avatar
Car: '81 Z-28
This may only apply to carbs and TBI, but it should have an idle adjustment screw. It has been a while since i messed with TPI, but if you adjust the idle, and set the pressure to around 45 you should be good. Manual will have the right pressure, I think it's 45 psi, but please double check. I don't have my book with me.
specialized
Jun 18, 2022 09:26 AM
jklein337
Sep 19, 2018 06:23 PM
Infested
May 22, 2018 11:56 PM
bamaboy0323
Sep 3, 2015 06:07 AM
