Clunking under hood while driving — possible bad motor mount?
Old Aug 13, 2020 | 05:15 PM
cosmonautpg's Avatar
Car: 1992 Camaro RS
Engine: LH0 V6
Transmission: A4
Hi all — while driving my 92 Camaro RS V6 3.1L recently I started hearing an occasional “clunk” or “thud” sound from under hood (possibly felt through the acceleration pedal, too).
It’s difficult to tell but I think it is worse during acceleration and braking, sometimes occurring when just driving steady on side streets.
I got some video of the engine with the hood popped — no clunking sound but some motion of the engine itself. Is this an unhealthy amount of movement for the engine? Is it time to redo the mounts?
Here’s the 10 second clip of the engine:
Thanks!
Old Aug 16, 2020 | 06:57 PM
Mark RWC's Avatar
Re: Clunking under hood while driving — possible bad motor mount?
Lots of things including bad engine or transmission mounts can cause clunking sounds on a 28 year old vehicle. A link to a video on diagnosing bad mounts is at the end of this reply. Loose or failing suspension part or accessory bracket can cause noises also. I had the power steering bracket crack only find it is no longer made by GM. There was noise from the engine compartment before it failed.. A thorough inspection of the front end, brakes, engine mounts and engine accessories may help you find the problem.
Schrodingers Box
An overlooked technique for diagnosing bad engine mounts. Just doing the "rocking test" does not always show the problem!!
Old Aug 18, 2020 | 02:12 PM
Car: 1992 Camaro RS
Engine: LH0 V6
Transmission: A4
Thanks for this! Upon further inspection, I think I can rule out the mounts.... I suspect something suspension related now so I need to dive into the rods, arms, and bushings and see what is loose or dead.
Old Aug 19, 2020 | 12:56 PM
Car: 1992 Camaro RS
Engine: LH0 V6
Transmission: A4
Upon even further inspection, it looks like my tie rod bushings have had some accelerated grease loss in recent times -- the ones on the passenger side were nearly dry and the tie rod was very loose. I gave the vehicle a chassis lube (as a quick fix before I dive into doing a rebuild/replace in the future) and it has fixed the issue! Seems like that tie rod was bouncing around a lot with the suspension moving.
I was able to reach 7 out of the 9 zerk fittings on the bushings for lubing... I need to get a 90 degree adapter or something similar to get to the ones in the top-most positions where the fittings would face toward the rear of the car.
Anyway, I'll call this resolved (and a note to future folks who hear clunking in the future and automatically thing "engine mount" first).
Old Aug 19, 2020 | 01:50 PM
OrangeBird's Avatar
Car: 1989 Firebird
Originally Posted by cosmonautpg
..... and the tie rod was very loose. I gave the vehicle a chassis lube and it has fixed the issue! Seems like that tie rod was bouncing around a lot with the suspension moving.........Anyway, I'll call this resolved ......
The clunk will be back sooner than later . If the tie rod is "very loose" greasing will shut it up for the very short term , but the play in the ball & socket will pound that grease out in no time .
If it gets bad enough and separates , well , best to not go there and replace it now rather than tempt both Darwin and the Gods of fate at the same time ......
Old Aug 19, 2020 | 02:03 PM
Car: 1992 Camaro RS
Engine: LH0 V6
Transmission: A4
Fair point! I haven't been driving many miles lately, to be honest, due to the pandemic so maybe my band-aid will last a little longer than a daily-driving situation. Regardless, I've added the parts required to rebuild to my shopping cart so that it will remind me to pull the trigger in the next month!
Old Aug 21, 2020 | 06:28 PM
Car: 1992 Camaro RS
Engine: LH0 V6
Transmission: A4
Quick update — after driving around the block about 3 miles for a checkup, I started hearing the clunk again. Snapped a photo of that passenger side outer tie rod bushing oozing. Yeah, maybe I’ll just go ahead and rebuild...
Saxondale
Jun 14, 2016 08:24 AM
gman1989
May 21, 2012 06:13 PM
camaro430sut
Jun 6, 2007 03:05 PM
Blackroc86
Apr 4, 2003 04:21 PM
zupmanZ28
Feb 21, 2003 11:18 AM
