I think my 305 has gone to heaven
Old Apr 18, 2012 | 01:31 AM
gman1989's Avatar
Car: 1983 trans am
Transmission: 700-r4 B&M console megashifter
hey guys here's my problem after several months of procrastinating my transam finally started the engine was idling a little rough so i set the timimg again since the last time i forgot to tighten the distributor and adjusted the carb and closed the hood just then i hear a loud sound like a hammer hitting an I beam i'm thinking oh $h#t broke a motor mount and dented my hood i kiled the engine checked and the motor mounts are good i go to turn on the engine and when it does there's a really loud knock and since i'm fairly new to the world of mechanics i as wondering if you thirdgen gurus can help me
Old Apr 18, 2012 | 06:44 AM
ex-x-fire's Avatar
Re: I think my 305 has gone to heaven
You guys need to use capital letters, periods, comas, ect.
Old Apr 18, 2012 | 06:52 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Well I wish I had good news for you but first check all your pulleys and water pump for problems.
Old Apr 18, 2012 | 06:52 PM
gman1989's Avatar
Car: 1983 trans am
did that all pumps and pulleys are secure and not loose
Old Apr 18, 2012 | 07:06 PM
Edwardgp's Avatar
Engine: 454-350
Will the engine turn over and run or is it seized up?
Old Apr 18, 2012 | 07:43 PM
gman1989's Avatar
Car: 1983 trans am
turns over and runs but there's a loud knock and i dont know what it is
Old Apr 18, 2012 | 08:26 PM
Stevolwevol's Avatar
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
Try removing the belts, and see if it quits making noise. Only for the moment.
Old Apr 18, 2012 | 08:35 PM
Edwardgp's Avatar
Engine: 454-350
Yes try what Stevo posted and is the noise still there when it is running.
Old Apr 18, 2012 | 08:59 PM
I have also heard of bad smog pumps making awful noises when they fail. I don't believe your engine has walked into the light yet. Not at this point.
Old Apr 18, 2012 | 09:01 PM
gman1989's Avatar
Car: 1983 trans am
belts are off and smog pump not installed still hear the knock
Old Apr 18, 2012 | 09:36 PM
gman1989's Avatar
Car: 1983 trans am
called my dad and he said it might be piston slap?
Old Apr 18, 2012 | 10:51 PM
gman1989's Avatar
Car: 1983 trans am
Well if it turns out that my engine is a goner. then I guess I have no choice but to go 350.
Old Apr 19, 2012 | 01:46 AM
305's go to the other place anyway. This would be an excellent time to do what gman suggested. Tons of 350's out there.
Old Apr 19, 2012 | 01:56 AM
gman1989's Avatar
Car: 1983 trans am
maybe you can clarify for me what's the difference between 2 bolt and four bolt main?
Old Apr 19, 2012 | 02:52 AM
gman1989's Avatar
Car: 1983 trans am
Originally Posted by bookfire1238
Great site. A lot of useful information here. I’m sending it to some friends!
links????
Old Apr 19, 2012 | 09:03 AM
I think the 2 bold will take no more than 500 hp. Therefore, I don't think it matters one iota. If you find a good deal on a 2 bold 350, than I'd go for it.
Old Apr 20, 2012 | 01:19 AM
iroczracer07's Avatar
Car: 1989 Camaro
Engine: 350 but it's torn down right now.
Axle/Gears: I'm working on it,lol.
Take the valve covers off and see if you bent a pushrod. You might want to check the rocker arms too while you're in that area. I wouldn't give up on the motor just yet.
Old Apr 20, 2012 | 03:47 AM
gman1989's Avatar
Car: 1983 trans am
will do thanks for the advice. If I find anything wrong i'll post up some pictures so I can be nudged in the right direction as to what I need to do
Old Apr 20, 2012 | 04:08 AM
Flora62's Avatar
Old Apr 20, 2012 | 03:54 PM
gman1989's Avatar
Car: 1983 trans am
I don't want to be an a$$ but i'm asking for mechanical advice not grammar so if you can't help me please don't post unless it's mechanical thank you
Old Apr 20, 2012 | 04:53 PM
davidjr74's Avatar
Car: 1985 Camaro Iroc
Engine: 350 tpi
does the knock happen over and over again as the engine is running? or just one loud one?
Old Apr 20, 2012 | 05:03 PM
SDTransAM's Avatar
Car: '83 z/28
Axle/Gears: Stock?
My suggestion to you. GO take the car out, hammer the **** out of that little 305 until she blows. That's why I am doing to mine. Then build a 350 and smile haha.
Old Apr 20, 2012 | 07:13 PM
Edwardgp's Avatar
Engine: 454-350
OK Gman we need more information on the knock. Like davidjr posted is the knock over and over or just once.
Old Apr 21, 2012 | 12:35 AM
gman1989's Avatar
Car: 1983 trans am
the knock is over and over and it gets louder when i rev the engine
Old Apr 21, 2012 | 07:22 AM
Edwardgp's Avatar
Engine: 454-350
Alright if it was mine I would drain oil and then slowly pour it through a paint strainer. I would look for pieces of brass and metal. Then it would be time to yank it out.
Old Apr 21, 2012 | 01:40 PM
Car: 1989 Camaro
Did you check the push rods and rocker arms yet? On my 94 Z28 I had a noise that was loud, Turned out to be an exhaust gasket. So before tearing anything else apart, I'd look check around the manifolds, or headers, depending on what you're running.
Old Apr 21, 2012 | 02:42 PM
I was thinking the push rod thing myself. I know with stock or tired valve springs you can float out with too high of revs, and a push rod can loose contact with the rocker. Not to uncommon for small blocks, and not hard to fix.
Old Apr 21, 2012 | 04:54 PM
Edwardgp's Avatar
Engine: 454-350
Have you done anything in the way of following up on any of these good suggestions.
Old Apr 21, 2012 | 11:10 PM
gman1989's Avatar
Car: 1983 trans am
good advice but I already started taking apart the engine yesterday. And before I bought it the car was parked for 14 years so I think it's time to replace anyway.
Old Apr 23, 2012 | 12:24 AM
gman1989's Avatar
Car: 1983 trans am
I just told a friend of mine about my engine problem. And he offered to sell me an ls1 from his camaro for $400. The only problem is that it has a blown head gasket. Should I go for it and if so will it bolt up to my 700r4
Old May 18, 2012 | 08:38 PM
gman1989's Avatar
Car: 1983 trans am
guess what guys I pulled my engine out and just found out that the hunk of iron was rebuilt before and that loud a$$ knock whas the starter which came loose and got thrown into my exhaust pipe and some how left a hole the size of a silver dollar
Old May 18, 2012 | 08:54 PM
Well, that must have been a relief. Too bad you had to pull the motor the find this out.
Old May 18, 2012 | 08:57 PM
gman1989's Avatar
Car: 1983 trans am
big relief but its not bad now i can degrease the engine and bay there's years of crap built up in there
Old May 21, 2012 | 06:13 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Good news. I was just going to suggest a possible cracked flexplate.
pjsparts
Oct 29, 2025 06:39 PM
db057
Apr 28, 2019 07:45 AM
383cam
Sep 9, 2015 06:01 AM
rsrookie
Sep 5, 2015 07:08 PM
Formula_88AE
Sep 3, 2015 01:47 PM
