Cold Idle Problem
Old Sep 29, 2020 | 12:47 PM
Nova73's Avatar
Car: 1986 Camaro Sport CP V6 MPF
Engine: V6 173cu MPF
Transmission: 700R4 Automatic
Cold Idle Problem
When I first start my 86 Camaro V6 engine it does not want to idle properly or steady and sometimes shuts off. What part or sensor should I be looking into to correct the problem?
When the engine is hot it idles fine.
Problem solved: Bad ground connection at Battery to engine block.
Old Sep 30, 2020 | 03:04 PM
Mark RWC's Avatar
Re: Cold Idle Problem
Car requires more fuel when cold so check fuel pressure. Idle Air Control and Throttle Position Sensor are possible issue. Check for vacuum leak with spray of carb cleaner when cold.
doglogan
Carburetors
May 31, 2011 01:59 PM
Alphius
Oct 12, 2006 03:24 PM
lostangel
Nov 3, 2003 03:23 PM
