oil preasure
Old Oct 26, 2020 | 07:29 AM
mikiman's Avatar
oil preasure
Hello from Spain.
What is the correct oil pressure with the car idling?
sometimes it goes to about 1000 rpm and other times to 2200 rpm, and the oil pressure to the maximum. Thank you
Old Oct 26, 2020 | 02:58 PM
GeneralDisorder's Avatar
Re: oil preasure
It depends on the temperature of the oil. The stock "trim package" isn't very accurate. The pressure doesn't much matter as long as it's not zero or close to zero. Is the engine in some kind of distress?
GD
Old Nov 2, 2020 | 12:14 AM
mikiman's Avatar
Re: oil preasure
OK.
The machine give me the 22 code. Steering column low. And the idle it's slow and the car stops sometimes. But it was stopped since 8 years.
thanks
blackdragon4_12
Nov 8, 2007 12:34 PM
outlawracer
Oct 16, 2006 10:30 AM
V8 Slayer
Jun 21, 2005 11:56 PM
Tremo
Jan 18, 2004 01:45 AM
The Dirty Bird!
Jul 23, 2003 03:52 PM
