V8 Radiator swap with a V6
Hey, Guys!
I have a 1989 2.8L V6 Firebird. Recently, my radiator became clogged. I found one online and purchased it. However, to my dismay, the radiator configuration is swapped, as it is actually meant for a V8 (my bad). Is it possible to put the two together? My only concern is the sharp angle it’ll cause off the water pump. Any help or know-how is deeply appreciated.
-1989Jack
-1989Jack
Car: 85 Iron Duke, 88 GTA and 92 TA
Re: V8 Radiator swap with a V6
IIRC you can just buy upper and lower radiator hoses from the 3.1 liter V6. The 3.1 V6 has the same radiator as the V8.
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
Car: 86 Firebird
Engine: 2.8l V6
What about the Automatic Transmission lines. My 2.8 V6 trans lines are on the passenger side.
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
