V6 missing
Old May 8, 2021 | 03:54 PM
DIPDAVIS's Avatar
V6 missing
start the car in the morning runs great -every morning- drive to work park it and come back has serious misfire - not back fire- runs ok has no codes. replaced ignition spark control modal, cap, rotor, and wires. looked at spark plugs all look fine and the same, dont smell anything like fuel or oil burning.
86 2.8 firebird bored out to 3.4 mpfi stock ecm except of EGR a while ago cleaned MAF with spray
Old May 8, 2021 | 03:58 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: V6 missing
You can try to isolate to the effected cylinder by pulling the plug wires with spark plug wire pliers .
or use a inferred gun and point at exhaust manifold ports. Could be a bad injector.
Old May 8, 2021 | 04:02 PM
DIPDAVIS's Avatar
Re: V6 missing
did the infrared thing found on cool but not sure why "start up" it's fine any ideas
Old May 8, 2021 | 04:05 PM
Engine: Lb9
Transmission: M20
Re: V6 missing
Might want to get warm and pull the plenum and ohm injectors.
Old May 8, 2021 | 04:07 PM
DIPDAVIS's Avatar
Re: V6 missing
yea I was hoping for push this button and all is better LOL
thx
Old May 8, 2021 | 04:09 PM
DIPDAVIS's Avatar
Re: V6 missing
different question I have uprated injectors 17 lbs i actally want to replace them with something - rebuilt- better and have read several different opinions about end types
Old May 8, 2021 | 04:22 PM
Engine: Lb9
Transmission: M20
Re: V6 missing
Might ask southbay fuel injectors opinion. Rebuilt older bosch might be a good injector.
but being a larger cid might want to datalog and tune or see if there is a afpr available.
iirc 3.1l is the same fpr as tpi but not sure if anything other than modify to external pressure regulator.
knightinblackar
May 30, 2016 01:40 PM
VaneGTA
Aug 22, 2003 03:46 PM
qytum
Jul 17, 2002 07:15 AM
87_Camaro
Aug 28, 2001 10:17 PM
