3.4l v6 Oil Tube Removal Secret?
Old Aug 11, 2021 | 03:41 PM
fishermandude's Avatar
Car: 1985 Sport Coupe
Engine: 2.8 MPFI
Hoping someone can help with the "Top Secret" process of removing the oil tube. I trashed 2 so far in a wrecking yard with no luck. Even offered to pay for the yard to pull one for me and was told that "cant do it without wrecking the tube". I tried searching for an aftermarket part# with no success there either.
If anyone has an extra tube lying around I would be more than happy to be its new owner.
What is the secret?? There are 2 (wrecking yard) opportunities to score one if i can get them out without trashing them.
Any help would be great.
Old Aug 31, 2021 | 01:20 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
Re: 3.4l v6 Oil Tube Removal Secret?
The dipstick tube?
try youtube.
I hear its by luck if you can squirt some PB blaster and wiggle it out.
If not, Ive seen people go from the bottom and tap them out
Old Aug 31, 2021 | 02:42 PM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
Is it different than the v8? All I did was hose mine down with penetrating oil, undo the securing nut, and started with a bit of twisting. After I was able to twist the bracket off the stud, I had to pull it in exactly the opposite direction that it faces into the block (at an angle). They don't seem to like bending at all.
Old Aug 31, 2021 | 04:52 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Ok now I remember what I did... My 2.8 one came right out.
my 3.4 came broken, so I turned the motor over and used a punch from the bottom to lightly tap it out. put lots ofPB blaster (actually WD40 at the time) and slid the 2.8 right in. .
Excellegions
Jul 14, 2011 09:33 AM
djmarch
Mar 16, 2011 08:16 PM
dtorres
Apr 2, 2010 02:52 AM
86z/92rs
Jan 2, 2005 11:00 PM
primer84z
Mar 31, 2002 11:24 PM
