Need some help!
Old Oct 16, 2021 | 02:49 PM
Mikejay's Avatar
Car: 1989 Pontiac Firebird
Engine: 2.8L V6
Need some help!
Hey everyone!
So yesterday I picked up a 1989 Firebird with a 2.8 V6. There are some parts missing such as the alternator (already have a new one). Now I feel like I am still missing more parts. I just need an outside perspective from yall, and maybe make a quick parts list?
Thanks!
Mike.
Missing parts?
What was given to me in a box for the car.
Old Oct 16, 2021 | 04:08 PM
Gordon G E's Avatar
Car: Got me a nice little '86 Z28.
Engine: A brand new 350 with a forged lower
Transmission: 5 speed, TKO600.
Axle/Gears: 10 bolt 373 modified zexel.
Re: Need some help!
All those parts are the brackets the hold the alternator to the block. Not sure why the P.O. took them off but they will need to be bolted back on the front of the engine. Look up serpentine belt in the how to section. Might be a diagram there for you.
Old Oct 16, 2021 | 05:38 PM
Mikejay's Avatar
Engine: 2.8L V6
Re: Need some help!
Thanks!
Old Oct 28, 2021 | 03:06 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
Re: Need some help!
It's minor, but it looks like your heater control valve is broken and you are missing the hose that goes onto the water pump nipple
Old Oct 28, 2021 | 03:36 PM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
Re: Need some help!
It's gonna become pretty major as soon as that engine turns over and starts shooting coolant everywhere!
How long has this car been sitting? If it's over 1 year, I'd use a hand pump to siphon as much fuel as possible out of the tank, and replace it with 5 gallons of fresh. If it's more like 5 years, then the valves could be stuck and you might want to pop the valve covers off and give each rocker arm a whack to make sure they return. Of course, if you pop the valve cover off, you should clean the gasket channel and replace the gaskets with nice fel-pro silicon gaskets.
Check each plug wire, make sure they're still bendy and connected. If they're brittle or have any sort of breaks, replace them immediately. I usually go ahead and replace spark plugs, plug wires, cap, and rotor regardless of condition because it's pretty cheap and easy to do, but that can wait until you've gotten the engine running assuming the plug wires aren't dangerous.
Check for smoke, smells, noises, when you hook up the battery for the first time. Be ready to disconnect it if you get smoke, for sure. Check oil and coolant levels, note where they're at as it might help diagnosis later. Check brake fluid and transmission fluid if you're gonna try and drive it.
usafirebird
Mid-West Region
Mar 27, 2021 04:01 PM
Bill33976
Apr 7, 2013 08:50 AM
Demon355
Feb 17, 2007 01:11 PM
MetalliCamaroRS
Jan 30, 2004 10:16 PM
Cruzin Kaz
May 17, 2003 03:25 PM
