Serpentine drivebelt smoking
Old Jan 9, 2022 | 03:21 PM
KITT87's Avatar
Car: ‘87 Base Firebird
Engine: 2.8 V6
Hi, I recently put a new serpentine drivebelt on my 1987 Firebird with the 2.8l V6. However, the new belt has been smoking when going around the pulley below the alternator. The metal behind the pulley sparks occasionally as well and the metal behind it became red hot when the engine revved high. Probably a stupid question but any ideas on how to make it stop? We’ve tried losing and tightening the pulley to no avail.
Old Jan 9, 2022 | 03:37 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Serpentine drivebelt smoking
Why do you need the idler ? Is it bearings shot ? Looks like you could toss is and run a shorter belt.
Old Jan 9, 2022 | 09:08 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
That idler looks to be running crooked like the bearing is shot.
Old Jan 10, 2022 | 05:20 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Replace the bearing in the idler pulley. It is easy to do and is a common bearing. Remove idler from bracket, press out bearing, press in new bearing, bolt back up.
RBob.
Old Jan 10, 2022 | 07:31 PM
KITT87's Avatar
Engine: 2.8 V6
Thanks for the quick replies! I’m new to cars in general (as you can probably tell) and it’s great that there’s a good community around the 3rd gens. The idler pulley bearings were indeed shot so I threw a new one on there and it’s as good as new. Thanks again.
Tootie Pang
Sep 17, 2020 08:00 PM
Archs89
Aug 3, 2011 05:03 PM
AC
Fabrication
Nov 29, 2009 02:22 PM
camaronewbie
Jul 7, 2009 04:27 PM
warrior_91
Nov 5, 2003 12:48 PM
